Author Topic: 11.28 - New Project Day  (Read 3020 times)
  • Administrator
  • Brian
    • madbeanpedals
« on: November 28, 2010, 11:31:05 AM »
The Double Flush has been released and is ready for consumption. This is an excellent little tremolo that will fit in a 1590B and is relatively cheap to build. Find out more on the Projects page under the "Modulate" section:
http://www.madbeanpedals.com/projects/index.html
Note that I spent extra time on the documentation for this one. This is the level of detail you can expect on future projects, as well. I'll have pics and sound samples up ASAP in the the Build Reports section of the forum.
« Last Edit: November 28, 2010, 01:46:58 PM by madbean »
Micpoc
  • Solder Ninja
Re: 11.28 - New Project Day
« Reply #1 on: November 28, 2010, 01:06:04 PM »
Great, been looking forward to this one!   :)
  • Josh
    • 1776 effects
« Reply #2 on: November 28, 2010, 02:36:54 PM »
Very nice documentation!!!  You're making it to easy  ;)
crashguitar
  • Stompbox Star
  • Chad
    • Able Archer
« Reply #3 on: November 28, 2010, 03:34:59 PM »
Cool! I need a trem on my pedal board.
aziltz
  • Solder Ninja
« Reply #4 on: November 29, 2010, 01:01:50 PM »
i'm a little confused about the difference between the Balance and Intensity Controls on the new trem.  In my head I'm imagining them both controlling how much Trem gets Trem'd?
Obviously you felt the need to include both, so I'm just wondering what the real difference is.  Does Intensity affect waveshape at all?
  • Administrator
  • Brian
    • madbeanpedals
« Reply #5 on: November 29, 2010, 01:32:56 PM »
They are definitely different. The Balance control simply provides variable resistance to mix the modulated and base signals, whereas the Intensity has a more direct effect on the waveform. At minimum it is a fairly gentle ramp and at max it sounds more square (chopper effect).
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
« Reply #6 on: November 29, 2010, 02:55:36 PM »
Hey Brian...
Projects are looking good! Can't wait to see more!
scdesigns
  • Transistor Tickler
« Reply #7 on: November 29, 2010, 06:20:55 PM »
Will this also be produced as a fabbed board in the future? I ask because im curious with future releases will there be the option to either etch our own or buy the fabbed versions?
Thanks
  • Administrator
  • Brian
    • madbeanpedals
« Reply #8 on: November 29, 2010, 06:37:35 PM »
All projects, insofar that it is practical, will include a single sided version for etching. There may be some in the future that are released directly as fabbed boards. But, nothing that I know of for sure. Even the vibe project has a single sided layout that will fit in a 1590BB.
If this one does well, it will be fabbed...it might even be the same layout. I don't think there is  much hope in making it a lot smaller.
But, the DIY layout is there in the document to be used, too. It's always your choice!
pauloman80
  • Stompbox Star
« Reply #9 on: November 30, 2010, 08:43:08 AM »
Schweet! *two thumbs up*
Regards,
pauloman80
aziltz
  • Solder Ninja
« Reply #10 on: November 30, 2010, 09:45:03 AM »
Thanks for that explanation Brian, I knew there had to be more to it that I saw.  It sounds like a very 'organic' trem for lack of a better word.  Not cookie cutter at all.
Haberdasher
  • "El Duder-ino"
« Reply #11 on: November 30, 2010, 04:42:49 PM »
Awesome, you rule Brian.
Incidentally, when the projects page is viewed in opera the modulation section is displaced way off to the right.  (I didn't know which forum to put that in, so I hope here is ok)
cheers
FABRICATED PCB's FOR SALE:
plesur
  • Stompbox Star
  • Dan
« Reply #12 on: December 01, 2010, 06:37:22 AM »
This is cool. I was working on a layout for the Trembulator with an output buffer but you beat me to it and added extra icing! I'll definitely be building this one soon.  :)
  • Administrator
  • Brian
    • madbeanpedals
« Reply #13 on: December 01, 2010, 07:23:55 AM »
I'm so happy to hear people are excited about this one! Keep an eye out for an interesting mod for this one in a couple of weeks....think of what real time control over this one might be like (not tap tempo---something else).
eniacmike
  • Solder Ninja
  • Mike
« Reply #14 on: December 01, 2010, 07:38:19 AM »
optical eye? expression pedal?
I just ordered one of these:
excited to add an expression jack to some projects.
