Author Topic: Enclosure size templates for artwork  (Read 41120 times)
Knut Koupee
  • Diode Destroyer
« on: December 09, 2012, 11:40:36 PM »
Is there a graphic format available (to use in photoshop or something similar), blank, for various enclosures sizes in actual size ready for waterslide printing?
In particular I have need for 1590bb right now, but other sizes would be cool too (1790ns, 1590b, etc)
Thank you :)
  • John - Wakefield, UK
    • Juan's Gnomepage
Re: Enclosure size templates for artwork
« Reply #1 on: December 10, 2012, 03:38:59 AM »
I've shoved my Photoshop Templates here.
Sizes are from 1590A (mini) to 1590XX (huge)
The layouts are laid out around Josh's Optotron board (apart from the mini which is a 3PDT). Generally they're quite tight. But it's all layers anyhow so you can move it all around.
« Last Edit: August 07, 2014, 02:06:45 AM by juansolo »
JuansoloFX Stompage - DIY effects library & stuff
(NOT commercial)
“I excite very large doom for days” - playpunk
Tremster
« Reply #2 on: December 10, 2012, 01:22:41 PM »
Knut Koupee
  • Diode Destroyer
« Reply #3 on: December 10, 2012, 10:25:41 PM »
Thanks for the links. Is Large the 1590bb? At 100% it looks HUGE. Not sure if it is meant to be 1:1 or not. A layer with dimensions would be super handy (knob 1 is .5 inches from both corners or whatever)
Still trying to figure this out, would be nifty to get a drill template and graphics pattern match :D
Knut Koupee
  • Diode Destroyer
« Reply #4 on: December 10, 2012, 10:26:25 PM »
Here as well: http://diy.musikding.de/index.php/195.html
Thanks for the link. Unfortunately that file format is supported by an application that doesn't run on my operating system (OSX).
  • Jimi Lee
« Reply #5 on: December 10, 2012, 11:31:32 PM »
Pedal Vectorpack is what I use.
http://www.ontheroadeffects.com/vectorpack/
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
« Reply #6 on: December 10, 2012, 11:51:13 PM »
It works, you just need to fix the file name. If it says .svg.xml, delete the .xml part, and then you can use Inkscape to open the files.
Hangingmonkey
  • I only started doing this to make a cheap TS808
« Reply #7 on: December 11, 2012, 08:48:01 AM »
Cool, thanks for sharing the templates
crashguitar
  • Stompbox Star
  • Chad
    • Able Archer
« Reply #8 on: December 11, 2012, 10:34:33 AM »
Thanks, I just grabbed the pedal vector package. Looks pretty cool!
Chad
Mike @ Rawkworks
  • Stompbox Star
  • Mike
    • RawkWorks
« Reply #9 on: January 30, 2013, 10:05:11 AM »
Thank you for the links
    • Juan's Gnomepage
« Reply #10 on: January 30, 2013, 02:22:53 PM »
Yep, large is 1590BB. Print it out and it should be the correct size. They do seem large on screen.
« Last Edit: August 07, 2014, 02:07:09 AM by juansolo »
(NOT commercial)
Briman1974
  • Diode Destroyer
« Reply #11 on: February 21, 2013, 01:58:07 AM »
Which one is for the 125b size and 1590b? Thanks for your help.
decsnspace
  • Diode Destroyer
« Reply #12 on: October 25, 2013, 11:42:24 AM »
juansolo,
I downloaded the pstemplates that you posted a while back. The templates have been very helpful for me to use as a base template design for creating guitar pedal images in photoshop. However I recently copied over the file I had for your 1590A enclosure and now the link to your website seems to be broken or dead.
Did you happen to move the templates to a new location on your site or did you just decide to take them down?
Any chance you might be able to provide a new link for us or maybe post a copy of your 1590A template that I could use?
If so, much appreciated as I'm currently building the bacon bits, runt, and afterlife and this template would be a lifesaver! Thanks! ;)
    • Juan's Gnomepage
« Reply #13 on: October 25, 2013, 02:50:45 PM »
Ah yes, I did a lot of updates to them and forgot to put them back... They'll be back there in a sec
EDIT:
Back there now.
The CB1590B template is for a Camden Boss 1590B.
I've updated the 1590D/DD and it's now more accurate... It's also the template for a Space Ritual if you fancy making one ;)
The 1590Av2 is for a using 16mm pots and those new tiny jacks we've got.
The rest are pretty much as they were, all set up for Josh's Optotron boards.
« Last Edit: October 25, 2013, 02:54:29 PM by juansolo »
(NOT commercial)
decsnspace
  • Diode Destroyer
« Reply #14 on: October 25, 2013, 03:55:25 PM »
Very cool!
Thanks for updating that link juansolo!
I went ahead and saved your new templates just in case I make the same mistake again.
Here's what my Bacon Bits (aka "Rocket Boost") design looks like that I created using your template. I replaced the 9vDC text with the cent_neg.jpg which I found on google.
