POST YOUR PEDALBOARD / GEAR!
Started by pandadandan, December 13, 2010, 05:26:35 AM
Muadzin
The odd thing is that while you think its simple, to others simple is..... relative? ;)
Marshall Arts
#211
Quote from: Muadzin on October 07, 2016, 07:47:06 AM
Well... yeah... but.... compared to all of my other boards, this is drop dead easy [emoji1]
Edit: Meanwhile I covered the top with velcro and improved the mounting on the bottom side - I changed the relevant pictures in my post. Does it look simple enough now?  ;D ;D ;D
Muadzin
To quite jimilee, simplistically complicated. ;)
How does the headset mic work out. I've been thinking of getting one of those for a while now. I hate having to lean over towards the mic (across my pedal board) as I think it adversely affects either my playing or my singing. I might just barely be able to sing and play guitar, not a good multitasker, so add leaning over towards a mic and that's asking too much of my processing thinking power.
Marshall Arts
Quote from: Muadzin on October 10, 2016, 05:57:44 AM
I am quite happy with the microphone in terms of sound, but you need to be aware of two things:
1) Volume-control by changing the distance to the microphone does not work - I am not that dynamic (in general  ;)), and the TC compressor does the rest
2) Putting it on and off is a PITA - Take of the glasses, put the mike on, clip the XLR-Jack to your belt, put on guitar, put on glasses. You need a mute switch for that procedure (that's why I built one).
Highway31
#214
That's mine! At the moment....  ;D
Top (in the dark): Carl Martin Power Supply - DIY Level-Tone-Control for the Korg - Korg G4 - Tuner - Battery pack for Wah and Gain & Balls
Middle: Vox Time Machine
The rest: DIY Looper to switch between Time Machine and Korg G4 - Rockett Dude - DIY Gain & Balls - Amp1 - George Dennis Wah
brejna
Quote from: Highway31 on December 08, 2016, 03:39:40 AM
That is great board! :) Since you got there Amp 1, please I need some feedback.. I watched almost all clips online and I am close to buy it. Thomas blug did great job with it. What do you think?
Muadzin
I recognize that case. That's a Rockcase, right? I used to have 3 of those, I kinda wore them out.  ;D
Highway31
Yes, it's a Rockcase but modified to my needs  :D
I bought the Amp1 soon after it was on the market and tested it with different speakers and cabinets but I was
not 100% satisfied. So, I returned it within the 30-days-money-back-guarantee.
Months later I made a 1x12" cabinet for a friend and his Amp1 and we tested all of my speakers. The
winner was the WGS Veteran 30. We were very impressed by the Amp1/WGS combination.
Weeks later I ordered a second Amp1 and buildt two 1x12" cabinets. One for home and one for the rehearsal room.
I compared my cabinets against the Bluguitar Fatcab -had one at home for two weeks- but the Fatcab was too 'fat' for me  ;D
I found the perfect combination for me. It works great...Clean,overdriven, Distorted...With Stratocaster, Telecaster and Les Paul guitars. ;D ;D ;D
devilsnight
In the spirit of DIY here is a board I made last year with a couple of pedals I made myself. I gotta laugh a little at the simplicity of it all but, perhaps I'll update this soon! There are definately upsides and downsides to this sort of "board"
brejna
Quote from: Highway31 on December 09, 2016, 10:08:49 PM
Thanks for info. I am also building a 212 cab with WGS Veteran 30s for Rocket I am working on, so I am glad it is great combination with Amp1 :)
Thanks again
Cheers
Brane
cresconio
Thought I should share my current setup. The chain is as follows:
Korg Tuner -> Morley Wah/Volume -> H&K Tube Factor -> BOSS CH-1 -> DIY Deluge (BYOC Tremolo, everything spray painted) -> DIY Fuzz (No idea what it is, bought it from a friend) -> Ibanez CF7 -> MXR Phase 90 -> Boss DD-6 -> EHX Holy Grail Nano -> Boss GE-7
Current goal is to get rid of most of the pedals and replace them with something I built myself. And I need to get a looper of some sorts, I'm done tapdancing.
cajone5
^^^Nice!
2017 -- the year of the DIY board conversion.  I have the same goal.  If I can build something that replaces a commercial pedal (that I can sell to fund other things), I want to get it done this year.  I'm about 1/2 way there now and want a full DIY board with limited exceptions by years end.
cloudscapes
Haven't done one of these in a while.
your collection is fantastic. I mean all your diy builds are otherworldsly anyways, but to add a red panda particle, the strymons and then to top it off, the montreal assembly count to 5?! I'm positively jealous.
drolo
my new setup, slowly coming together after our move to the new house
