Glitterrattii LED Wiring
Started by ilikeguitars01, January 01, 2011, 12:56:16 AM
ilikeguitars01
So I noticed most designs don't show the led wiring, so I have done what I usually do on other builds. I wired the negative to the top middle lug 2.2k resistor on positive lead of LED wired to DC jack. The LED worked, so I stuffed it in the enclosure, powered it on and it flickered then it wouldn't come back on.  The pedal still works great. So I replaced the LED just in case I shorted it out when putting it in and got the same result. So I took out the resistor after looking at some pictures of other builds and still no LED. Can someone point me in the right direction as I have a sunking I have to put a LED in too. Thanks !!!
stecykmi
there are some wiring diagrams in stickies at the top of this (sub)forum.
ilikeguitars01
So there is.. you know I read the top one didn't even see that one. Thank you!
