Anything unique about a reverse log pot aside from the taper?
Started by Vivi, January 06, 2011, 06:18:20 PM
Vivi
In my anxious rush to order parts for my Krankosaurus and Serendipity builds, I managed to forget quite a few things, including a second 5K reverse taper pot.  Would using a 5K pot with a normal linear taper change anything about the pedal aside from said pot adding instead of removing when turned (or vice versa)?  Thanks.
I think you're misunderstanding how pots work.
A 5k linear pot will be fine.
Vivi
Eh, I won't argue with that.
Good to know that it will work though.
rowland1
I refer to this webpage pretty regularly: http://sound.westhost.com/pots.htm#markings
It describes different pot tapers, shows a nice graph illustrating Log and anti-log (reverse) tapers versus linear.
I agree that linear will be fine. I hope that helps.
