Uproar facemelter decreases volume
Started by repertuaari, May 19, 2011, 09:36:23 PM
repertuaari
My Uproar is sounding good but it seems that I cannot get the facemelter mod work properly. I put 33n cap in the C10 slot and 22k resisor in the CP slot (both are socketed). When I engage the mod, the sound changes a bit (not very much) and the volume decreases quite a bit. I assume the volume should increase instead? Any idea what could be the problem?
-Reima
repertuaari
I'm also having problem spotting the difference between clipping modes and the same problem has been mentioned on the forum earlier. As I removed the red led clipping and used the other clippings individually the difference was much clearer. So it seems I have to get on/on/on DPDT switch and do the alternate switch wiring.
