NGD + Opinions Wanted
Started by culturejam, August 03, 2018, 08:56:41 PM
dan.schumaker
I know I'm late to the party and you already have your config picked out, but I wanted to chime in that I think doing it up like this would be cool
Quote from: dan.schumaker on August 05, 2018, 11:27:19 PM
Is that a single up front? I might be up for that with a bucker in the back. I'm going to mull things for a few more days.
That's a serious bridge pickup too.
Aristatertotle
Quote from: culturejam on August 06, 2018, 12:08:13 AM
Here's a better picture of that Strat.
If your Strat has a pool route, you could keep the battery in there and not have to route for a battery compartment. Would be a bit of a pain to have to take the pickguard off anytime you need to change the battery though.
Quote from: Aristatertotle on August 06, 2018, 03:01:53 AM
Yeah, that looks great.  I'l also a fan of Daphne Blue with a white guard and EMGs.
GermanCdn
All right, I'll throw out a love it or hate it option.
Two P-Rails, V/T setup, two DPDT switches for the pickups (or 1 if real estate is an issue), and an on board Bloviator (trimmer pots inside to tune, switch in the second tone position to bypass).
P-Rails are the Swiss Army knives of pickups - they don't do anything particularly great, but they do a decent job of all three.  I have found they sound better in Fender-ish guitars and longer scales.
Quote from: GermanCdn on August 06, 2018, 01:10:14 PM
Throw a couple of push pull pots instead or switches.
GermanCdn
Quote from: jimilee on August 06, 2018, 01:18:49 PM
Yeah, the push pots for the P-Rails limits your switching options to Humbucker OR Single Coil OR P-90 (i.e both pickups are setup in the same configuration, so if you want to run a HB in the bridge and a SC in the neck, you have to mission control the switches) if I am not mistaken (it's been a few years since I installed one).  Two switches gives you the AND ability in that configuration.
