Kezuroukai whine
Started by TNblueshawk, December 18, 2023, 11:05:58 PM
TNblueshawk
So everything seems to work great but for the classic high pitch wine. It's on all settings. It's so loud it makes it unusable.
Anyone have any suggestions on what tweaks I can make?
John
I don't recall anyone complaining about a whine before. But, I think it would probably start in the Feedback path. So, even with FB all the way down you still hear it? Does the pitch change with the Rate setting?
TNblueshawk
Hey Brian thanks for chiming in.
Yes, even with the FB all the way down. The pitch barely changes with the rate but it does.
No matter where I toggle and what switch I hit the whine is there. It alters a bit or a lot depending on what combo of sounds I land on. Maybe a bad IC issue? I haven't yet taken voltages if that would matter.
John
TNblueshawk
Ok, so oddly enough I had bought the Redshift from Aion and just tested it. I get the exact same whine with the same symptoms of combo of sounds altering the pitch and speed of the whine.
What is the common denominator ( yeah I know besides my soldering iron  :o)? The LM13700. Sooooo, could I have gotten a lousy batch? Might it exhibit the dreaded whine? I would not ever recall where I go those. Sure it could have been Tayda but I can't say.
I have no idea what projects I have done in the past that might have this chip. I will need to do a little recon on some other phasers that I have that work to see if I can swap some out.
John
Power supply. Phasers are sensitive to line noise. I was pulling out my hair and I must have disassembled a phaser a dozen times before I figured that out.
TNblueshawk
Quote from: jimilee on December 20, 2023, 09:04:18 PM
Ok, I'll play around with that a bit. I did have a regulated wall wart but I'll pop into my good PS on my board.
John
Quote from: TNblueshawk on December 20, 2023, 09:07:53 PM
TNblueshawk
Jimilee, you are the man. That's all it was. Many thanks JL.
Bean, to your point, no there is no whine in the circuit!  ;D
John
Quote from: TNblueshawk on December 23, 2023, 08:58:03 PM
Glad I could cut down on your frustration and it worked. Phase on!!
