Rub a Dub reverb
Started by night-B, August 03, 2012, 05:50:42 AM
Knut Koupee
Quote from: GrindCustoms on August 24, 2012, 06:23:58 AM
So lets say R12 input eyelet goes to lug3 of pot, lug 2 --»33nf--»ground and lug1 goes to R12 output outlet.
Some questions:
1) Can ground be the top of the pot or does it need to go to the ground pad on the board?
2) How do I know which of the two pads for R12/13 is in the In and which is the out? Or does it not matter which pad goes to lug 1 & 3?
3) Does it make any difference if R12 or R13 is used? R13 is near the edge of the board and might be easier to pull out.
Thanks!
Quote from: Knut Koupee on December 17, 2012, 11:39:35 PM
Some questions:
Thanks!
1) Technically yes, if your enclosure is grounded, but I'd recommend grounding at another point.
2)Follow the schematic with the layout. Sorry I left this with not much info because you'll learn more if you figure it out yourself  ;)
3)no
