Catch-22
Started by G.G., September 23, 2014, 03:43:40 PM
G.G.
Hi Guys,
This uses the snazzy red Grind Customs board. So many misadventures along the way with this one I was really glad to finally be able to use it. I had soldered in the board-mounted pots and then got the impression that I had reversed the Gain and Volumes labels on the decal, so I unsoldered the pots and wired them in so I could reverse their positions. Then realized the decal was actually correct, and had to put the board-mounted pots back in. Then when I did a pre-box test there was no sound at all. It was either a bad charge pump IC or a cold solder joint somewhere because it came to life after I went over it a few times. I probably could have done top-side jacks had I planned it out better. Sounds very good now, excited to have it on the board!!
brand0nized
Awesome! I want to build this one too! Is that a 1590b?
brejna
G.G.
thanks guys! Yes, it's in a 1590B.
muddyfox
What's the story behind the name?
G.G.
Quote from: muddyfox on September 23, 2014, 05:20:44 PM
It's the Portuguese version of the name of the circuit it's based on. Not super creative but I needed to get the decal done quickly.
mjcyates
Looks great! I really like the sound of the one I built.
GrindCustoms
Looks great Gray! Glad you sort it out and mostly that you dig it :)
wstimson
Looks good, man.  I finished one of those up a couple weeks ago and I'm enjoying it.
What op amp did you end up using?  I tested out 4 different ones and settled on OP275.
G.G.
I think I went with a 2272. Which ones did you try & how did they sound? I need to test a few out, but was so pleased to actually have it working I forgot about doing that.
wstimson
I tried the 2272, tl072, op275, and the nec5532.
We aren't talking about huge differences, but I felt the distortion was a bit more appealing with the op275.
Monochromatic in the coolest way!! Very well done!
Guybrush
Looks ace. I recally dig the red knobs.
G.G.
thanks again guys! I see that Tayda has the op275 so I'll give it a try, thanks for the tip!
karter2000
Yeah, I just tried the op275 with mine, and I really like it.
