05.19 - LaVache and Cosmopolitan
Started by madbean, May 20, 2011, 12:27:18 AM
bigmufffuzzwizz
I posted this in the wrong thread, and meant it as a follow to go in this one!
Here's a few more details: it's based on the Escobedo Wobbletron and has a bunch of mods. First, instead of using a transistor to create the vibrato, it uses a complete implementation of the Univibe LFO. This drives a small 18v lamp. The advantage of this over a transistor or LED based approach is the smoothness of the ramp up and down of the actual lamp. It's more natural and less choppy than an LED, I went with a tiny lamp to make this thing fit into a 1590B with ease.
Next, it has an added JFET input buffer and a simple bi-polar output gain stage. Lastly, it has a switch so that you can change between vibrato and pure tremolo.
I'm looking into getting a supply of the specific lamp I'm recommending. It will actually require a Road Rage board, too (or a charge pump, at least).
sgmezei
Looks awesome Bean! Any idea when the BOM will be up. I'm doing some ordering....
crash
I have all the components for the LaVache, except the 3.3M resistors.  Could I use 2.2M resistors for these instead, or will that mess up the biasing?
sgmezei
You could put the 2m2 and another resistor in series, twist them together like a tipi to get as close as possible. I will let one of the smarter chaps comment on the biasing though.
2M2 + 1M1 = 3M3 or if you have a 1M you can get close at 3M2
crash
I suppose I can do that in the short term, then put a 3.3M the next time I place a component order.
highway jones
Cosmo's are gone..  Crap!  i waited too late.
I'll have a few more soon. I'll etch a new panel in a couple of days.
