sunking troubles
Started by t-rack, December 31, 2010, 12:15:24 AM
t-rack
so i finally got some sound out of this thing after some minor trouble-shooting,and i found d3 was bad, but now im getting a signal through the pedal but it sounds almost over distorted and if i turn the gain up all the way it sounds like a fuzz pedal! the only thing that i noticed was that pin 7 of ic2 was less than 1 volt even after swapping out the chip.
any thoughts?
stecykmi
check the values of the resistors again, you might have too high of a value in a feedback loop somewhere...
this will probably take you a while, there are a lot of them...
