Leviathan delay isn't working. Where do I start?
Started by xorophone, November 26, 2016, 11:11:15 PM
xorophone
Hello!
I've recently finished my Leviathan delay from Etcher's Paradise. I etched a circuit board myself and it turned out good, but after soldering all parts the effect didn't work. I don't think there's anything wrong with the offboard wiring because the LED works like it should, the 3PDT wiring looks correct and the bypass works. When the effect is turned on the guitar signal goes through the pedal, but there's no delay applied. It's very hard to tell, but the signal might get a tiny bit amplified by the TL072 chip, so it seems like that one is working. It's of course really hard to tell when using a dynamic signal source though, so I'm not sure. I know it's impossible for you guys to troubleshoot it, but I just want you to tell me where I should start in the troubleshooting process.
Here's some information about modifications and stuff I've done to the circuit (please tell me if these could affect the circuit in any way):
  • I've used a 510k resistor instead of 511k (R2)
  • Many of the ceramic capacitors have been replaced with monolithic capacitors. For instance every 100pF.
  • I've used chinese PT2399 chips (and TL072 for that matter.) so there's a risk that my chips just aren't working.
I'm guessing the 510k resistor shouldn't make any difference, but I don't know about the monolithic capacitors, so please tell me if there's any problems with using those. Is there a way to check if my chips are working or should I just buy some real ones and hope they work?
I also checked the DC voltages on the chips using my multimeter, so here's that information:
PT2399:
1: 5v
2: 2.39v
3: 0v
4: 0v
5: 2.86v
6: 2.39v
7: 0.57v
8: 0.60v
9: 2.39v
10: 2.39v
11: 2.39v
12: 2.39v
13: 2.39v
14: 2.39v
15: 2.39v
16: 2.39v
TL072:
1: 4.26v
2: 4.28v
3: 4.17v
4: 0v
5: 4.25v
6: 4.28v
7: 4.28v
8: 8.58v
It looks perfect to me, but please tell me if there's anything wrong with it or if I should measure something else.
If you want pictures or something I can post that too. Just let me know!
Voltages look pretty good. You need to audio probe the circuit and find out if the PT2399 is getting signal and putting out any delay at all or if the signal is dying somewhere else.
I know it's an official project, but it's helpful to have the schematic right here:
When you audio probe, test:
1. Both sides of R10
2. Lugs 2 and 3 of the repeats.
3. " " of the LVL
Start there, and check the components in between until you find where the signal is lost.
There may be a couple places where you don't hear signal. Don't panic! You won't hear anything on the - input of an op amp.
xorophone
Quote from: selfdestroyer on November 30, 2016, 10:32:55 PM
I would definitely add some pictures.
I'll upload some pictures as soon as I have the time. :)
Quote from: madbean on November 30, 2016, 10:34:46 PM
Quote from: midwayfair on December 01, 2016, 02:57:50 PM
3. " " of the LVL
Thank you for the replies! I'll try probing it when I have time. Midwayfair, I'm guessing you mean the pots when you say "repeats" and "LVL". Is that right?
And what do you mean by
3. " " of the LVL
xorophone
#5
Here's some pictures:
Sorry for the bad underside photos. Please tell me if you need better pictures. I wanted to avoid having to desolder all the wires.
3. " " of the LVL
I started audio probing yesterday and I got some very interesting results.
  • There's both dry signal and delayed signal on both sides of R10. The dry signal SEEMS TO BE a tiny bit louder on the side facing the TL072 chip, while the delay signal on the side facing the TL072 chip is much quieter than on the other side. The repeat and delay pots affect the delay signal just like they should.
  • Lug 3 on the LVL pot outputs delay signal, but no dry signal.
  • Lug 3 on the RPT pot outputs delay signal, but no dry signal.
To me all of that information looks right. Where do you think I should continue probing? Which path should I follow? Sorry but I'm still pretty new to guitar pedal building so it's hard for me to know where it pays off to probe.
Another thing I forgot to mention is that I've soldered some resistors on 2 of the pots to try to change the pot value and/or the taper. I DID NOT know what I was doing but I decided to experiment with it. On the RPT pot I've soldered a resistor between lugs 1 and 3 and on the TONE pot I've soldered a resistor between lugs 2 and 3. This shouldn't really prevent the pedal from outputting the delay signal though, from my understanding.
Edit: Sorry for the horrible soldering by the way. ;) The solder kept travelling up the tip of the iron and landing on the tracks beside the pad. From my knowledge there's no solder bridges though. It was a lot harder soldering homemade PCBs than I expected.
xorophone
#6
I just did A BUNCH of audio probing and actually noticed that there actually is delay applied to the output-signal, but it's VERY low in volume. It's very hard to tell if the LVL pot actually makes any difference in volume, but I can still hear some delay when it's on 0, so I'm guessing it isn't working as intended. There's delay signal going in to pin 3 of the LVL pot, so maybe I'll have to try replacing it.
Quote from: xorophone on December 05, 2016, 10:43:29 PM
This is something to keep in mind too. The LVL pot doesn't have a resistor on it.
What should I try next? I really want to finish this project now because I was planning on giving it away for christmas. In Sweden we celebrate christmas the 24th, so I'm under a lot of pressure. So please, if you have any idea, please tell me!
Merry Christmas!
Edit:
This of course prevents me from probing the components between the LVL wiper and pin 6 on the op amp, which makes it a bit harder.
The other side of the level pot is an inverting op amp input, so you won't hear anything there. But you have narrowed it down. Check, re-check, and triple check the components between the wiper of that pot and the op amp. Maybe you swapped a cap, or maybe you used a 120K where you should have used 12K, maybe there's a short to ground. But it's only a few components.
On the underside, where is says leviathan, make sure those aren't bridges. Check the whole board against the PnP.
xorophone
Quote from: midwayfair on December 23, 2016, 02:19:40 PM
Quote from: jimilee on December 23, 2016, 06:50:26 PM
I actually fixed it! ;D I'm extremely happy now because this was my first big pedal project and I really wanted to give it away for christmas!
I tried bypassing the LVL pot using a wire, and it worked fine so I decided to replace the potentiometer, which fixed the problem! The value was right so I just think it was broken. I'll have to measure it some day using my multimeter and find out what the problem was.
The tone pot isn't working great (I used a higher value and used a resistor to change the taper, but I think it just made it worse.), but I don't really care about that. Most of the change happens in the beginning of the rotation (the pot value seems to high and the taper is a bit crazy too), but I'm not even going to bother fixing it because I'll probably just break something else. It's not that important.
Merry christmas everyone and thank you so much for the help! :)
Congrats, what a great gift. Merry Christmas!
