6.1mm resistors
Started by Hangingmonkey, August 18, 2013, 06:22:53 AM
Hangingmonkey
Hi all, Id really appreciate some help on this.
Im gathering the parts for a valve preamp I saw on DIYSB andI need 6.1mm resistors.  Ive had a look on google and no luck, I dont even know what they are.
The BOM states these:
R1     68k         6MM.1        R0207/1V      6mm Resistors
Anyone know anything about 6.1mm resistors and where I can get them from?
Heres the thread, check out the GTFO preamp:
http://www.diystompboxes.com/smfforum/index.php?topic=93936.0
6MM.1 is from the Eagle library designator thingy.
1/4 watt resistors will work just fine :)
kothoma
#2
Without reading through the whole 15 page thread, isn't R1 standing anyway? Almost any size will fit.
Hangingmonkey
Thanks guys,  I wanted to make sure the higher voltage running through the circuit wouldnt kill the resistors or set them alight or something!
I'll post up the finished version once its completed, assuming I get it working...
