Tinnitus Industries HM2 v2
Started by selfdestroyer, December 28, 2014, 10:27:30 AM
I thought I would post this here since a few of you have built this PCB. It been driving me nuts and I have have taken a few breaks from it and decided to give it another go.
Build Doc:
https://dl.dropboxusercontent.com/u/19219628/hm2v2.pdf
My PCB looks a little different than the one in the doc and I think the3secondrule said this was a working proto and he just moved a few parts around to clean up the layout some. He said that the part numbers all match up to the BOM.
(1) Project Name
(2) General description of the problem
I get just static/white noise and if I turn up the volume all the way I get a bit of audio.
(3) Steps that you have taken to try to resolve the issue
I have checked my parts and orientation on all polarized parts. I have probed around some but have a hard time finding any faults.
(4) List any substitutions you used for parts/values
I made this awhile back but I am pretty sure there were no subbed parts.
(5) Volates?
Q1
G 0
S 4.3
D 9.5
Q2
E 0
B 0.6
C 3.9
Q3
E 8.6
B 7.9
C 4.5
IC1
1 4.5
2 4.5
3 4.5
4 0
5 4.7
6 4.7
7 4.7
8 9.5
IC2 & IC3 (exactly the same)
1 4.7
2 4.7
3 4.7
4 0
5 4.7
6 4.7
7 4.7
8 9.5
(6) Pictures?
Don't judge me on my flux mess. I usually clean before I box up a circuit. Also the orientation was wrong on Q1 J201 when I took the picture. The silkscreen image was wrong on my version from what I can tell.
Soup39
what are you using for your Q's? Are the pinouts correct? have you sub in different to ensure you don't have a crappy one in there?
the3secondrule
I'll get some voltages on my build when I get home, bust everything looks good to my eyes .
I'll also double check which fet I used on the proto's. I think it was a 2sk30a on the proto and I switched to j201 afterwards. Might need some leg twisting if you only have j201s
Thanks for the help guys, I will have some bench time tonight to play around with this some more. Looking forward to seeing voltages of a working unit or to see if my pinout is wrong with the J201.
Got it going. It was the J201 pinout. Since I have the proto board I forgot that mine follows the V1 layout which had the 2SK30A (Like the3secondrule) suggested. Looks like the Gate and Source are swapped on the J201. Once I crossed over the leg it fired right up. This thing sounds great but I could only play with it for a few minutes since my floor was getting really hot from all the hell I was raising with the pedal dimmed.
Thanks again guys.
