Lovetone Doppelganger - Work In Progress
Started by irmcdermott, November 14, 2012, 04:53:50 AM
irmcdermott
Quote from: electricstorm on November 15, 2012, 03:10:13 PM
What size enclosure is that and is it a Hammond enclosure?
It is the 1590DD clone from Mammoth. I will say, I definitely would recommend getting the 1590D, the extra height would be extremely helpful. I'm going to make this work, but it is going to take a lot of planning to keep the jacks from shorting against the board. Keep in mind also, It will only work using the slim enclosed jacks. Maybe using the 1590D would allow you to use the standard open frame jacks, but not here.
Long story short, at the minimum, use a 1590D. I'll share my drill template when I get home from work.
Stomptown
Search "pulsar" on the forum. There a couple of threads with instruction and advise. Ian started the most resent one, you might try searching his most resents post.
[/quote]
Finally I can learn how people are doing the white graphics! Thanks and great job! Looking froward to seeing the final product....
the3secondrule
This thread reminded me that I've got a doppelgänger board that Keefe had etched for me.
Still gotta finish my stringringer build first though
;D
electricstorm
You still have that drill template for your Doppelganger? How did the boxed pedal turn out?
Jim
ElectricStorm
No current affiliations
