Cupcake swirled compressor
Started by Gledison, July 02, 2014, 06:33:11 PM
brejna
Awesome finish (Y)
What type of colours do you use?
Sent from my HUAWEI G510-0200 using Tapatalk
Gledison
Quote from: slimtriggers on July 02, 2014, 09:35:42 PM
That swirl came out great!  I've never been able to do one successfully.
Thanks man! It's actually pretty easy, really. Maybe u just need the right materials?
Cheers
Gledison
Quote from: brejna on July 03, 2014, 06:11:53 AM
Awesome finish (Y)
Cheers mate! I'm using magic Marble paint. No need for borax. just a bucket with water and the paints. I add no more than 20 drops of the main colour and 5 of the secondary ones.
Let me know if u need any help.
Gledison
Quote from: pryde on July 03, 2014, 12:58:03 AM
Quote from: catfud on July 02, 2014, 10:03:21 PM
Great swirl and finish!
That's what I said when I flushed the toilet this morning  :D
Seriously that is a cool pedal. Nice job.
Eheheheh! So u throw a swirled pedal in the toilet? Hahhaha
brejna
Quote from: Gledison on July 03, 2014, 07:53:18 AM
Awesome finish (Y)
Thanks for info, I use those colour too. But it seems that I've been mixing to much paint, so it gets dry very quickly.
Do you use cold or hot water? and does i matter?
Sweet, I still haven't tried to do swirl finish, this is pretty nice
Do you start with an unfinished box, sprayed white, etc?
Fwiw I had to mount my cupcake upside down too, better use of space and I was still using tall caps at the time
Gledison
Hmmm! Yes it matters a lot! I've noticed that some colours dry faster than others! I use cold tap water , normally around 20 deg Celsius! Too hot and you will have a quick skin formation! With this colours u need to work very fast! Usually i do all the process within 1-2 min! Also don't forget to use not to much paint! U need enough to cover the surface of the water. The secondary colours just 3-5 drops! Quick swirl and dip it!!
Good luck and let me know your progress!
Cheers
Gledison
Quote from: wgc on July 03, 2014, 03:45:36 PM
Yeahh! I have only tall caps so allways a pain!
Regarding the finish: i wetsend the box with a 600 grid, than 1200! Than clean with some spirit! Then, automotive white primer for aluminum! 3 or 4 coats! Than backed on a toast oven for 20 min, 50 deg C! Than swirled!
slimtriggers
This is great info.  Any chance for a tutorial?
That swirl is BEAUTIFUL.  Nice job.
Gledison
Quote from: slimtriggers on July 03, 2014, 05:43:57 PM
Mann, there are a lot of tutorials out there. i pick up different experiences from different people.
A very good one, is from "haveyouseenhim". He is using borax and enamel oil based paint. What im doing, is a ready to use Magic marble paint. That is the only diffrerence.
here is the link of his great youtube videos:
http://www.youtube.com/watch?v=8rnleOuOkL8
https://www.youtube.com/watch?v=YtXUvkpZm0o
Again, if you need any help from my side, please let me know! If its really necessary and has not been done yet here in the forum i can write down a new tutorial, no  problem.
Regards
Gledison
Gledison
Quote from: pickdropper on July 03, 2014, 07:51:15 PM
maaaan! comming from you is a great compliment! i love your pedals, very inspiring work!
thanks a lot!
Rockhorst
Perfect Swirl! Very sexy pedal!
