NPSITBSMNDCTCD
Started by midwayfair, February 22, 2013, 01:50:03 AM
ch1naski
Quote from: midwayfair on February 22, 2013, 02:11:50 PM
Quote from: eldanko on February 22, 2013, 02:09:18 PM
Does this mean your demos won't be filmed in front of the liquor cabinet anymore?
Unfortunately, it does mean that. :(
I will try to put something just as interesting (or at least more interesting than my face) on the green wall behind the amp.
just make sure a bottle of kahlua is in the frame.:D
one louder.
Stomptown
Cool jam space! Hopefully this helps ease the tension with the neighbor. And BTW, you are the bigger person is this situation for sure. Hopefully his occupancy is as short lived as his temper.  ;)
I could use a space like this myself. If I only had a basement  :'(
Jon, after you stuff the ceiling, cover and seal it with some 6mil plastic sheeting. If air can leak through the sound will get through as well so you need to caulk around the edges and make sure any openings for electrical boxes or whatever are sealed to the plastic covering. Coming along nicely, about he size of the corner i get to mess about in.
Take care,
Hey great job Jon... I hope this proves to be a useful setup for you :)
slimtriggers
I say DIY green screen.  You could chroma-key yourself into a different location with each video  8)
Quote from: slimtriggers on March 02, 2013, 03:33:19 PM
Hehe. "Today we are demoing the Tenebrion Reverb one thousand feet below sea level just outside of fuji. It seemed an appropriate location."
