Tap tempo Cardinal Tremolo - finally, after a long road paved with difficulties!
Started by Cortexturizer, August 16, 2016, 11:17:37 AM
monkeyssj1
Wow this is one of the builds i think i've seen coming from the community. Such a beautiful/top tier job!
I am flaberghasted and humbled. That looks perfect.
I have once again been taught that it's not a good idea to say someone "can't" do something.
hylandren
You should be very proud for both this build and for sticking with this!
Impressive in every way.
beneharris
Coda-effects
Awesome build!
I really like the double potentiometers, what a gain of space!
Ticking is annoying with the TAPLFO (well I guess it is the same for every LFO digital ship), especially with square waves, I had the same issue, and removing the power supply resistor (100R), and adding a huge capacitor between the voltage regulator and ground (470uF) solved it too.
Aleph Null
Cortexturizer
You guys... thank you so much!
Last night I rehearsed with the pedal and it worked flawlessly and the sounds was fantastic. I've tried all the three modes, with clean and dirt coming into the pedal and it handles everything too well! Just a fantastic little pedal, thank you Jon!
chuckbuick
Beautiful all the way around, man.  Knobs, faceplate design, everything.  You killed it!
Cortexturizer
Thanks chuck! means a lot coming from you, I love your builds to death!
Everything about this build is incredible. Build of the year contender for sure.
Stomptown
Damn! You should be really proud of this one.  Over the top awesome in every way!
29palms
very cool, I like the knobs, impressed you got all that stuff in there too!
