I'm just about to solder in the 3p4t switch rotary switch on the Honeydripper. I notice that numbers and letters on the switch, which I purchased from Small Bear, don't exactly exactly line up with the numbers and letters on the board (pin 6 on the switch is going into hole #7 on board). It fits perfectly this way and doesn't fit any other way. Has anyone else noticed this? Do I have the wrong switch or is it just an error on the letters printed on the board?
I didn't notice it with my build, I was more concerned with the lining up the A B C.
Just make sure you soldered it onto the correct side of the board ;D
Yes realized I had it backwards. Too many beers on the workbench ....
