Projects => Tech Help - Projects Page => Topic started by: zapme on June 06, 2013, 12:23:55 AM
Title: Bloviator II Build Problem
Post by: zapme on June 06, 2013, 12:23:55 AM
I have built the bloviator II and is working great.  What resistor values can i modify to make the pedal unity gain.  My plan was to use it in the fx loop but it is boosting the signal too much and causing the power section in the amp to clip slightly.
Title: Re: Bloviator II Build Problem
Post by: midwayfair on June 06, 2013, 12:35:02 AM
You could jumper r7. That would reduce the gain by quite a bit.
Or add a volume control.
Post by: zapme on June 06, 2013, 04:29:24 AM
Thanks for the advice.  i tried the jumper, it dropped the volume way too much.  I settled on a 5k resistor for R7.  Would be cool to put a volume pot in, i might have to do that in the future.
