Projects => How Do I? Beginner's Paradise. => Topic started by: funky see on June 26, 2013, 08:06:53 PM
Title: uber beginner seeks advice
Post by: funky see on June 26, 2013, 08:06:53 PM
hey, i'm building my first pedal, it's the Bumblebee with the road rage side car. I ordered almost all of my parts from pedal parts plus but could not find some of the caps- 100n, 4u7, and 1n.. also seeking a 3k3 resistor and an NKT213. I am an absolute beginner so go easy on me.
nick
Title: Re: uber beginner seeks advice
Post by: midwayfair on June 26, 2013, 08:11:58 PM
You aren't likely to find any NKT213s. As noted in the build doc, they're very rare now and there's really not any sense in paying what they would cost you anyway. Smallbear Electronics sells a matched 3-transistor PNP germanium set appropriate for the Buzzaround. You could also probably get a matched set of three transistors from Chromosphere - he just posted a web store. They'll be designated as a "Tonebender" set, but it works just as well.
The capacitors you mentioned are extremely common values, in fact 100nF is THE most commonly used value of capacitor in stompboxes. If you're getting the transistors from Smallbear, you could get them there to avoid shipping from multiple suppliers. Otherwise, every online retailer will carry them -- Tayda, Pedal Parts Plus, Mouser, etc. etc. etc.
p.s. mods, this should probably be moved to "beginner's paradise" or tech help.
Post by: DutchMF on June 26, 2013, 08:17:18 PM
I could help you out with all that stuff, except the NKT213's, but you might want to look a bit harder or try another source, like Tayda.com. The values you are seeking aren't that weird, so the usual suspects (Tayda, Mouser, Smallbear) should carry them. Good luck on the parts hunt, and if you have any more questions, do ask!!!
Paul
Post by: funky see on June 26, 2013, 08:18:18 PM
thanks!
Post by: funky see on June 26, 2013, 09:09:57 PM
for the bumblebee, I can't seem to locate the 100n, 4u7, and 1n capacitor. when I search the links, I'm not finding them?  The 3k3 resistor is also a tough one to find. I was able to get the replacement trans. for the illusive NKT 213. Am I not inputting the names of the capacitors/resistor correctly? i'm just copying what I see on the madbean parts list. sorry if my naivete is showing.
nick
Post by: midwayfair on June 26, 2013, 09:36:09 PM
Quote from: funky see on June 26, 2013, 09:09:57 PM
nick
Link for where you're searching?
Post by: murdog47 on June 26, 2013, 10:24:54 PM
It is very difficult to source parts from one supplier. Check out these links you will find what you seek  :)
mouser.com
smallbearelec.com
mammothelectronics.com
Mouser is my favorite for components but it takes some time to learn how to maneuver. Good luck!
Post by: funky see on June 26, 2013, 10:31:19 PM
hey, i've been to mouser, pedal parts plus, pedal mod parts, mammoth and fromel to name a few.
Post by: RobA on June 26, 2013, 11:03:19 PM
Are you looking for the axial caps? If so, they are a bit harder to source and you'll need to go to the more effects related places to find these.
Mouser should have all the ECQ type caps mentioned in the build doc. Just search for ECQ and then narrow to capacitors and then Film Capacitors. Once your are there, you can narrow by the values you need. You need to become adept at converting to the values caps are listed in. For example, the 100nF is going to be listed as a 0.1µF value and a 1nF Could be a 0.001µF or more likely a 1000pF. The 4.7µF caps are electrolytic caps, so you need to search for them under that category and choose whichever you like as long as they match the voltage specs that you need.
Post by: murdog47 on June 27, 2013, 12:10:20 AM
Quote from: funky see on June 26, 2013, 08:06:53 PM
nick
4u7
http://www.mouser.com/ProductDetail/Vishay-BC-Components/MAL202138478E3/?qs=sGAEpiMZZMtZ1n0r9vR22ciSY6ngmHpLokzq0e12LVQ%3d
100n
http://www.mouser.com/ProductDetail/Cornell-Dubilier/150104J100BB/?qs=sGAEpiMZZMv1cc3ydrPrF%2fUH96ueUpCvcEDiXgKCEiA%3d
1n
http://www.mouser.com/ProductDetail/Cornell-Dubilier/150102K630BB/?qs=sGAEpiMZZMv1cc3ydrPrF%2fUH96ueUpCvtuzHE1hNmD8%3d
3k3 resistor
http://www.mouser.com/ProductDetail/KOA-Speer/MF1-4DC3R30F/?qs=sGAEpiMZZMu61qfTUdNhGyWJXWeCdXjmOtoOr%2fNyRlE%3d
The caps I looked up are the axial ones not radial. You can go either way. Usually you can find radial caps cheaper. They are all out there....just gotta do some searching. You may or may not know this but:
100n = 0.1uf
1n = 1000pf
Hope this helps
Post by: funky see on June 27, 2013, 12:36:18 AM
Thanks so much !!  I've been playing guitar for over 30 years and recently, i've been doing demos for Ethos, Wiz-Pedal, Trombetta, and God Box. I always wondered what went on in these boxes so i'm off on this diy journey. you can see my demos on my youtube channel (Nick Caiano) One day, i'm gonna demo my own damn box! again...thanks for your patience.
nick
Post by: murdog47 on June 27, 2013, 01:01:59 AM
No problem! Glad to help. Sometimes sourcing the parts can be more than half the battle  ;D You found a good community to help get you going. A bunch of good folks around here. Don't hesitate to ask questions.
Post by: gtr2 on June 27, 2013, 11:18:01 AM
Here is a helpful resource as well when you need to convert capacitor values.
http://www.justradios.com/uFnFpF.html
It's also important to note small bear uses MF instead of uF.  They mean the same thing, he just uses the old MF nomenclature.
Josh
Post by: funky see on June 28, 2013, 08:51:27 PM
Thanks so much everyone. I was able to order everything on my parts list ! It's amazing to see all the choices when it comes to components and it seems that paying more for a particular part doesn't necessarily mean that it will sound great in a box. Again, thanks for the help.
Nick
Post by: Jean-Rock on June 28, 2013, 11:47:09 PM
Quote from: murdog47 on June 27, 2013, 12:10:20 AM
nick
4u7
100n
1n
3k3 resistor
100n = 0.1uf
1n = 1000pf
Hope this helps
Carefull with the last link......you mentionned 3k3, but this link is related to 3.3ohm.......It would be sad to order the bad value.........
Post by: murdog47 on June 29, 2013, 01:35:16 AM
Crap! You're right! My bad!  :o
Post by: murdog47 on June 29, 2013, 07:32:22 PM
If I messed you up with that bad link and you need any 3k3's PM me your address and I'll send some out to you! Sorry about that.
Post by: funky see on July 01, 2013, 02:34:09 PM
Hey y'all, any advice on a good mid priced soldering iron? I would also appreciate some of your sage advise on must have tools for a fledgling DIY'ER like myself?
Nick
Post by: RobA on July 01, 2013, 04:55:26 PM
Quote from: funky see on July 01, 2013, 02:34:09 PM
Nick
Kinda depends on what you mean by mid priced, but the Hakko FX-888 comes in at just less than (US)$100 and is pretty much perfect. It may be the best iron out there at any price.
Post by: murdog47 on July 01, 2013, 06:27:03 PM
http://www.gotopac.com/Hakko_FX888D_23BY_p/fx888d-23by-hak.htm?gclid=CPLUieP1jrgCFchDMgodLhEAvQ
On sale with free shipping
