Just wondering what members and Brian's of course thoughts on using SIP ICs would be?
On some of the more complex/IC heavy projects if they freed up enough space (they can be easier to layout for and do take up less space) at least for my preferences i'd rather a) smaller enclosure options/space for batteries, b) no 1/8w/ stand up resistors, that might just be me though, just find them a pain as the usual Tayda/Futurlec don't stock them and I don't have any in stock and i'm OCD about stand ups for reliability/looks and c) perhaps things like charge pumps built in to layouts that require them.
It does limit OpAmp choice but Tayda and Smallbear stock a small selection and a lot of the vintage projects used the standard 4558 anyway which can be bought in SIP.
Just an idea, if I want a build i'll buy a bean board regardless of if it goes against what I like :)
I've built a couple of 4558 SIP builds on vero (an Eternity build and something else I don't remember) and some fab (Rej's Octane uses a SIP 4558 if memory serves), can't say it was better or worse than DIPs, but I can see their usefulness in trying to maximize the smaller builds (though what you might gain in width, you could lose in height if you socketted it, which you would want to, because desoldering eight legs in line is worse than two sets of four, cause you can't really lever it). I modded up a couple of Boss DS-1 and had to remove the SIP chips from those, destroyed at least one doing it.
I usually build in a size up mentality (i.e. 1590A builds go in 1590B boxes), and I share your aversion to 1/8W and standing resistors/diodes.
Quote from: GermanCdn on July 24, 2013, 05:25:33 PM
Not sure about the difference on vero, with PCB traces though you can come in from either side more easily rather than being blocked by half an IC you don't want to use.
I never socket OpAmps generally, should come out with a good solder pump though (the spring load kind, not the squeezy kind) i've successfully removed them with relative ease from PCBs before.
If I can cram a build in a 1590B, I will :) If it's too complex, then I want it stuck in a 1590BB and nothing more if possible. I don't give my self extra space to work with and also find those to be the most common enclosures so it saves me specially buying something larger (usually at quite an increased cost).
I've had to deal with SIP only once, because of an Octane board kindly donated to me by Rej from GrindCustoms (thanks again mate, it's still in the works. Build report will follow, but I can't promise when...). I thought of a pretty neat solution to not owning (or wanting to order!) any SIP IC's. I'll look up the pics I took, be back with 'm shortly!
Paul
I bought a few of the 4558L's from Tayda because I figured they'd be easier for doing tight breadboarding because I could put all the op amp connections on one side of the breadboard and all the feedback/gain/filter structure on the other. I could see how this would make it possible to layout some circuits in a smaller space. I don't think the increase in height would be that much -- still below the height of the low profile electro caps.
I haven't really looked, but I haven't seen many SIP IC's for sale in the usual places.
To really help things get small, it's not that bad to solder in SMD op amps.
Quote from: RobA on July 24, 2013, 08:59:33 PM
Hm, hadn't thought of that, not a bad idea... shame they don't have SIP NE5532 but that could be a handy breadboard shortcut.
QuoteI haven't really looked, but I haven't seen many SIP IC's for sale in the usual places.
As I said, Tayda & Smallbear which I think a lot of guys here order through stock them, sure Mouser or Digikey have some... probably.
QuoteTo really help things get small, it's not that bad to solder in SMD op amps.
Woah now, let's not get ahead of ourselves :P Hand SMD puts a lot of people off, my self included.
Quote from: Scruffie on July 24, 2013, 10:35:17 PM
Yeah, I do understand that. It's pretty intimidating and is a general pain in the butt. But, for a few parts it wouldn't be that bad and could save a lot of space. Eight pin DIP's seems like a good place to start. It opens up the use of a bunch of the new op amps that don't seem to be coming out in though hole parts too.
Quote from: RobA on July 25, 2013, 01:54:30 PM
SMD isn't that bad when you get used to it!
I've done a few things, and have done an SMD version of the Nautilus (boards being fabbed at the moment) using everything SMD except the charge pump, i seem to remember. It now would fit in a 1590B quite easily, and also fit nicely in to my up coming multi build. bit harder to trace problems, but hopefully that won't be an issue too often!
Don't be too scared of SMD, once you get going, it's not too bad at all!
George
Quote from: hammerheadmusicman on July 25, 2013, 02:36:39 PM
I think I probably could do a few ICs in SMD if I tried, not that I have any desire too but in this case Bean has to think of his clientele, not everyone will be so easily convinced and I can see a lot of problems arising from beginners struggling with them.
SIPs are a nice compromise.
George
Quote from: Scruffie on July 25, 2013, 02:55:11 PM
... but in this case Bean has to think of his clientele, not everyone will be so easily convinced and I can see a lot of problems arising from beginners struggling with them.
Yeah, that really is the big question and it's a good point. It'll be interesting to see how it plays out over the next couple of years.
Back to the thread, are there many IC's other than op amps that are done as SIP's?
It seems to me that a good place to start with this idea would be to do one of the 1590A layouts of one of the classic designs that used SIP's.
Quote from: RobA on July 25, 2013, 04:50:09 PM
There's a couple of OTAs, not
quite the same as a CA3080/13600 but they could be converted and there's a few mini power amp chips, haven't looked in to much else.
Ohh! A couple of those OTA/VCA chips look interesting (looking at Small Bear).
Yeah, I'm into developing something. Narrow it down to a specific request or two, and I can start developing single in line package projects.
What about something simple like the a son of screamer type drive to start?
Quote from: RobA on July 25, 2013, 08:20:16 PM
They are, a bit better noise specs than the 3080/13700 I think too, but not sure how many Steve has in stock as they're NOS I think.
Quote from: jkokura on July 25, 2013, 08:23:15 PM
I was more thinking of using them for space saving on complex projects specifically than just for the sake of using them as I mentioned, there's no other benefit to them as far as I can see.
Other than those special SIP OTAs which have different properties.
If son of screamer is the same as a tube screamer then yes please.
Quote from: billstein on July 25, 2013, 09:43:52 PM
Well, it's a screamer without the in/out buffers. Think Eternity. Super easy to add/modify, and it's generally great sounding. Tweak the values in places, and you can get a lot of different dual op amp overdrive sounds.
This board from GrindCustoms required a SIP IC, which I didn't have, and didn't want to order. So I had to come up with a way to make it work anyway.....
(http://imageshack.com/a/img404/3165/r9ww.jpg) (http://imageshack.com/i/b8r9wwj)
I think I can still fit the diodes under there :D Added plus is that I can now experiment with the opamps I have lying around!
Paul
^ The true spirit of DIY :D.
Quote from: jkokura on July 25, 2013, 09:59:40 PM
Sounds good. I want one!
There are good and bad things about SIPs for layout purposes. I did the Octane layout (previously called the Inline 8) mostly because I'd never seen a DIY project with a SIP dual op amp.
SMT puts a lot of people off, but I am curious how many people who dislike it have actually tried it.
Now, I agree that some SMT parts can be challenging. Fine-pitch micro controllers and some of the smaller diode packages come to mind. Basic caps and resistors aren't that hard, and ICs aren't terrible, either.
In the end, they are different, but people hand solder them all the time.
