Projects => Tech Help - Projects Page => Topic started by: heavenwithin on August 11, 2013, 06:29:53 AM
Title: Zero Point SDX : Problem
Post by: heavenwithin on August 11, 2013, 06:29:53 AM
I built mine as per the build instructions. However on mode-1 there is random background noise , on mode 2 there is only 1 repeat when the path is switched on or off and on the other setting of path switch there is no repeat, mode 3 and mode 4 works perfectly. Every other knob/switch works perfectly. What could be causing this problem. Any ideas?
Title: Re: Zero Point SDX : Problem
Post by: heavenwithin on August 11, 2013, 07:31:39 PM
I changed the Tl074 to a Tl084 and now everything is fine. The delays are sounding awesome. But will this fit in a 1590BB measuring 120mmx94mm? anybody tried it? Please suggest.
Post by: kothoma on August 11, 2013, 07:42:57 PM
So your TL074 was defect. Sure it will fit:
http://www.madbeanpedals.com/forum/index.php?topic=9771.0
http://www.madbeanpedals.com/forum/index.php?topic=10602.0
http://www.madbeanpedals.com/forum/index.php?topic=10583.0
http://www.madbeanpedals.com/forum/index.php?topic=9006.0
http://www.madbeanpedals.com/forum/index.php?topic=10591.0
http://www.madbeanpedals.com/forum/index.php?topic=9739.0
http://www.madbeanpedals.com/forum/index.php?topic=8456.0
and on and on...
Post by: travorkates005 on August 12, 2013, 11:02:47 AM
Nice builds  :)
Post by: heavenwithin on August 12, 2013, 01:37:43 PM
Thanks for the threads' links kothoma... :D
Post by: kothoma on August 12, 2013, 02:15:32 PM
You're welcome!
