Projects => Tech Help - Projects Page => Topic started by: Narsil on September 18, 2013, 07:00:13 AM
Title: Dirtbag problem
Post by: Narsil on September 18, 2013, 07:00:13 AM
Hello,
This is my first post, so hello to everyone. Sorry for my English.
I have been trying to make this pedal sound properly, but I have had no luck yet. I started with the v3205 chips, then I tried the mods proposed by madbean. And now I have reversed all the changes and used 4x MN3008 and it seemed that this time could be the one.
It started sounding good but stopped. I have traced the signal until before C15. After C15 there is no signal. I do not know if maybe I have blown the MN3008s. I measured 16.5v from my power source.
I have no signal even with the chip removed. I do not know if this is normal or maybe is C15 the bad cap.
Thanks in advance,
Title: Re: Dirtbag problem
Post by: handlefras on September 18, 2013, 09:53:23 AM
Did you play with the bias trimmers? It is quite easy to bias this up so badly that you receive no delay signal at all. I assume you are still getting clean signal when the pedal is engaged and the blend pot is set to minimum?
Post by: Narsil on September 18, 2013, 10:24:57 AM
Thanks for your answer.
Yes. I have tried with the bias trimmers and there is no signal at pin 7 of IC4.
The effect was working ok and I was finishing with the gain trimmers. And I don't know what I did that the delayed signal dissapeared and I could only listen the clean signal.
