General => Open Discussion => Topic started by: Gledison on November 02, 2013, 02:07:41 PM
Title: how to snap the 30-PIN SIP SOCKET
Post by: Gledison on November 02, 2013, 02:07:41 PM
Hey guys!
Juat got this transistors strip socket and when i snapped three of them i snapped the crap all of it:p
How shall i snap the bloody thing off?
Cheers
Gledison
Title: Re: how to snap the 30-PIN SIP SOCKET
Post by: kothoma on November 02, 2013, 02:12:34 PM
Hold the fourth with flat pliers and push the first three between thumb and index finger.
(That's how I do it, assuming you're talking of these (http://www.taydaelectronics.com/media/catalog/product/cache/1/image/211x/9df78eab33525d08d6e5fb8d27136e95/S/I/SIP_Socket_2.jpg))
Post by: Jean-Rock on November 02, 2013, 02:19:10 PM
I use small cutter and it works well for me !
Post by: croquet hoop on November 02, 2013, 02:27:17 PM
Quote from: jonnyrockgear on November 02, 2013, 02:19:10 PMI use small cutter and it works well for me !
Same. I lay it flat and cut with a utility knife. "Lock" the blade in a ridge, press firmly, and it snaps easily.
Post by: stevie1556 on November 02, 2013, 02:30:55 PM
Stanley knife for me as well.
Post by: jimilee on November 02, 2013, 02:35:03 PM
I was using pliers but got lazy, they snap pretty easily for me, kind of insert your thumb nail and gently bend
Post by: Gledison on November 02, 2013, 03:04:46 PM
Hey!
Mine looks like this!
I think a knife could be the best solution...
Thanks
Post by: croquet hoop on November 02, 2013, 03:09:31 PM
Yeah, those are utterly unpractical, you always lose one row when you break them. Try getting the kind shown by kothoma, they're much better, and take less vertical space too.
Post by: Jean-Rock on November 02, 2013, 03:11:05 PM
Quote from: Gledison on November 02, 2013, 03:04:46 PM
Hey!
Thanks
Oh !! I understand why you find it hard to cut....You'd be better to get an other socket like the pic above !
Post by: Gledison on November 02, 2013, 03:12:41 PM
Quote from: jonnyrockgear on November 02, 2013, 03:11:05 PM
Hey!
Thanks
Yep! The ones above seems muchhhh better!!!
Post by: pickdropper on November 02, 2013, 03:36:01 PM
Yeah, there is a difference.  The ones Gledison has are for pin headers.   They won't really work as component sockets even if you can cut them cleanly.  Very useful with the mating pin headers, though.
The snap-off pin headers are really what you want to use for components.
Post by: Gledison on November 02, 2013, 03:55:04 PM
Buy cheap buy twice! Always right
Post by: RobA on November 02, 2013, 04:23:15 PM
Quote from: pickdropper on November 02, 2013, 03:36:01 PM
Yeah. The pin headers are good for connections you insert and remove all the time since they don't do any damage to the thing you're inserting. I use them for making jumper connections on breakout boards I make for breadboarding. I haven't figured out a clean way to cut them without sacrificing one hole each time. I don't think you can avoid it. But, now that Tayda has them very cheap it's not such a big deal.
For socketing components, you really want the type that Tayda calls 40 pin SIP sockets. They hold tighter.
Post by: Matt on November 02, 2013, 05:08:14 PM
I use end cutters and only cut halfway through.  It breaks off easily after that.  Haven't had too many casualties.
Post by: catfud on November 02, 2013, 05:59:26 PM
I've looked at using this kind of pin header soldered onto a board, to connect it to a solderless breadboard, and the pin fits fine in the pin header, but what do you use at the solderless breadboard end of the breakout cable? The same kind of pin header?
Post by: alanp on November 02, 2013, 06:13:50 PM
Tinning the wire should be enough.
Post by: RobA on November 02, 2013, 06:21:51 PM
I have a bunch of these http://www.adafruit.com/products/758 (http://www.adafruit.com/products/758) that I have split into various groupings of 1,2,3,4, and 6 wires that I use for connections between the breadboard and breakout boards and between breakout boards as well. I see that Tayda carries them now too, but I haven't bought any from them yet so I don't know how good they are.
You can just use solid core wire to do it to. I like the jumpers though because they are more flexible.
