Hey guys! I had this nice purple enclosure and printed my layout in yellow on a transparent slide! It looked quite ok. Than i decided to print the waterslide decal! I managed to print twice in the same spot in order to emphasize the yellow collor!
BUT after applying the decal , the result is not so great. I know that dark enclosures are difficult wit transparent decal! Please take a look and give me your comments! Shall i change and try a white collor on silkscreen? ( lot of work :( )
Thanks for the comments! All kind of it!
Not sure what you should do persay. However, that's really hard to see on the enclosure. You'd be better off going with black and some sort of bright colour as an outline or something.
jacob
On an enclosure that dark you're pretty much stuck with black if you want to see it.
Hi Jacob,
Ive tried black but ia even worse! My easist option i think is to get a white marker and draw over the decal! The prob is that i dint have a still handwriting! I knew i shouldnt start drinking so early :S
Yeah, often I outline. I think this looks great. If you are going to use it yourself and not try to sell it., leave it the way it is. I have a few I've done like that and as a matter of fact I'm working in another right now.
Another option to get closer to the look you want:
1) paint the top of the enclosure white
2) add a dark purple background to your label graphic
3) apply the water slide as usual.
The white makes the yellow show up and the dark purple background should blend with the rest of the enclosure.
Quote from: das234 on November 09, 2013, 07:30:16 PM
Hey mate, ive tried this with other enclosure and was very difficult to match the same bacground collor!
It cannot be seen in the pic but its a powder coated purple candy! Thats why i wanted to use a transparent decal!
Ive tried black but is even worse! I will try next ro add another decal on the top of it and see hiw it looks!
Thanka guys for the suggestions!
You know, what I would so is go to the web site of whomever powder coated it and sample the color with whatever graphics program you're using. I had to go to rust oleum web site to get a color match for some brown paint I was using with white waterslide, and I didn't need any part if it to be white.
Quote from: jimilee on November 09, 2013, 09:28:19 PM
hey jimmi,
I've tried this one with a red enclosure and was a pita to match the collor on the monitor with the final printed one. For flat colours I think would be easier. the one I have has a kind of prismatic effect and when I find some sample on google, it always has some schade effect..
lesson learned, no more dark enclosures...heheh
About having difficulties matching the color on the monitor with the printed one - change the color scheme to CMYK. Most programs work with RGB as a default but the picture gets printed in cmyk thus the difference. At least a dude at the printing store explained it to me like that, might not be the case with you. But I've always made the coversion since and all is well
Quote from: Cortexturizer on November 09, 2013, 10:30:32 PM
I will try, thanks!
Just need to find the bloody purple candy collor!:(
You can always label it Wii a paint pen.
On dark enclosures I use vinyl sticker paper - I would think white decals would also work.
On my purple enclosure I knew I couldn't match the color, but I also knew it would only be obvious to me. However, to make it less noticeable, I decided to use a lighter contrasting color for the background and use a little purple here and there. Cover it all with some clear with metal flake...
(http://i1254.photobucket.com/albums/hh606/bcalla44/Gristlizer/GristlizerExterior_zpsdd015863.jpg~original)
How about laser engraving? If there is a local trophy ship they should have one. It might cost a bit but it looks great...
Quote from: Stomptown on November 10, 2013, 08:29:59 PM
hey mate. actually there is one close by here. I will take a look. Do you have any pictures of such engraving? I believe it will than show up the aluminium colour through the purple right?
cheers
Check out Dave's sonic screwdriver. An amazing laser etch. That will give you a good idea of what you can do.
You could do it with the Pulsar Pro system. It's supposed to be able to do colored graphics on dark backgrounds, but I haven't tried that yet. I'm getting the white on darks pretty well, but still learning. I definitely have a love / hate relationship with that product. Not to mention, it's expensive to start and there is a steep learning curve. http://www.pulsarprofx.com/ (http://www.pulsarprofx.com/)
This is white on black wrinkle coat powder:
(http://home.comcast.net/~gprause/pictures/GAP_1.JPG)
Quote from: Gledison on November 10, 2013, 08:38:51 PM
cheers
Here is an example but definitely check out pickdroppers build reports. He is the master at this stuff. There are two things to consider when using a laser engraver. First, make sure your fonts and images are not too fine. You want thicker, bolder fonts and graphics. Second, the contrast between the design and enclosure is affected by the color. Purple us not going to give the best contrast, but I've done it and it works ok...
(http://imageshack.com/a/img208/3599/photo2jl.jpg)
