I need to get a replacement for this. what type of connector is this called? thanks a million in advance!
Layton
http://i53.photobucket.com/albums/g61/TreeSlayer/th_2013-12-06185411_zps8c42fbee.jpg?t=1386381251
IEC connector?
There are many variants (pin layout), so be careful when you choose the replacement.
edit: looks like what you need is the C14 variant http://en.wikipedia.org/wiki/IEC_connector#Appliance_Coupler_standard_sheets
Yup, it's an IEC. If you can wait then order it online for about $6.00 otherwise Radio Shack will gladly sell you one for about double that.
wow! that was quick! y'all reckon Mouser would have it?
Sure. For instance: http://fr.mouser.com/ProductDetail/Kobiconn/161-R301B07-E/?qs=sGAEpiMZZMv1TUPJeFpwbhNb2LLV2zw6wEih7O7UrUE%3d
(just check the datashet to be sure, but it should be okay)
Quote from: croquet hoop on December 07, 2013, 01:16:30 AM
thanks a million, Matt!! you're a life saver. if there's anything I can do for you, just holler!!
Layton aka the "TreeSlayer"
My pleasure :)
What are you building, and do we need to build one also?
Quote from: jimilee on December 07, 2013, 01:49:34 AM
LOL! actually, i'm rebuilding an old, cheap amp that one of my co workers was given. it's a transistor type. I have two tube amps, and actually this thing has a tone all it's own. it sounds cheap, but it might have a place. you ever seen one of these?
http://i53.photobucket.com/albums/g61/TreeSlayer/2013-12-06205711_zps355fd0ae.jpg
Quote from: TreeSlayer on December 07, 2013, 03:32:15 AM
No I haven't, but it looks most interesting.
It is. All I have left to do is replace the plug and finish up some of the other wiring and hope for the best! I'll post some audio later.
Sent from my iPhone using Tapatalk (http://tapatalk.com/m?id=1)
Quote from: TreeSlayer on December 07, 2013, 03:57:04 AM
Good luck sir, them things will fry and take you along with it. Be careful!
Will do, ole Bud. I know these things ain't no pedal! I've been very careful and double triple checking behind myself. Thanks for the concern. Take care! I hope the bad weather we've been getting doesn't make it to your neck of the woods!
Quote from: TreeSlayer on December 07, 2013, 04:15:00 AM
Nope, weather went North of us and just left a little bit of rain.
Cool deal Bubba!
