Projects => Tech Help - Projects Page => Topic started by: Gialli on January 22, 2014, 11:23:18 AM
Title: Bloviator doesn't work
Post by: Gialli on January 22, 2014, 11:23:18 AM
Hi everyone,
I've just built a Bloviator (etching the pcb) and it doesn't work. To find the problem I connected the output wire of a test rig on every components following the signal path from IN to OUT and on the output of the first input stage (Pin 1 of tl072) the sound breaks down, so I think there is the problem. The conductive tracks and components values are ok.
Here are the voltages on the Ics' pins
TL072
1 - 1.39
2 - 1.39
3 - 0.88
4;5 = 0
6 - 6.08
7 - 7.17
8 - 7.83
TL074
1 - 1.39
2 - 1.39
3 - 0.91
4 - 7.79
5 - 3.48
6 - 3.52
7 - 2.15
8 - 7.03
9 - 2.10
10;11;12 = 0
13 - 6.87
14 - 7
TL071
1,2,4,5,6,8 = 0
3 - 3.87
7 - 7.8
Here are the photos of top and back of pcb and a little video to explain my problem better.
http://it.tinypic.com/r/20pu70o/5
Title: Re: Bloviator doesn't work
Post by: madbean on January 22, 2014, 11:58:57 AM
Your supply voltage is quite low at 7.8v. Are you using a regulated 9v supply or fresh battery? If so, something is sinking your voltage...perhaps D1 is faulty.
As far as the tracks, have you tried a continuity tester to be sure? Specifically, I would look at making sure there is no continuity between the R4 pads and the ground plane, plus C3 and its adjacent tracks.
Post by: Gialli on January 22, 2014, 08:38:40 PM
Quote from: madbean on January 22, 2014, 11:58:57 AM
Thank you for reply, but unfortunately it doesn't work yet. I changed D1, controlled that there's no continuity between the r4 pads and ground and C3 and its adjacent tracks, the battery was fresh but I used a regulated 9v supply anyway, and with the power supply came out a 100 Hz signal. The voltages on the pins are rights? If not, can I know the voltages they should have?
Ps. With the battery, the voltage on 9v pin is 8.34 and the voltage drop on the diode is 0.74V. I think it's fully conducting, or not?
Post by: madbean on January 23, 2014, 02:58:16 PM
Voltages are completely off. IC3 seems to be the main culprit. Pins 2 and 6 should have about the same voltage as pin3. On yours, you have 3.8 going in and 0v going out. Ideally you would have about a 9v supply on pin7, about 4.5v on pin3 and then the same 4,5 output on pin2 and 6.
I would remove D1 first. Put a jumper there. Now reflow all the solder joints around IC3 and check again for solder bridges. Run a small utility knife between the traces. A bridge can easily escape the human eye but still be there.
Title: Re: Bloviator doesn't work [resolved]
Post by: Gialli on January 24, 2014, 01:41:14 AM
Ok, I fixed it, thank you very much for your help Brian! Pin 2 and 6 went to 0 V because there was a tiny tiny tiny drop of solder between the pin 10 of TL04 and ground track. I've been so stupid because that was a problem that I could see from the schematic, infact pin 6 of TL071 gives the voltage reference Vb, and it cannot be at 0V  ;D ;D ;D
