Projects => Build Reports => Topic started by: greysun on February 02, 2014, 12:07:27 AM
Title: Multiplex with modulation...
Post by: greysun on February 02, 2014, 12:07:27 AM
I wanted a multiplex, I wanted modulation in it, and I didn't want a horizontal pedal, SOOOO... I took the circuit for the 1776 modulation board and went to town with some perf board and 9mm pots to make it as SMALL as possible. I added a DPDT on-off-on toggle with LEDs so I can switch the modulation between delay 1 and delay 2. As you can see below, it worked and I was able to sneak a daughter board under the main board and not affect the pedal orientation!
(http://img.tapatalk.com/d/14/02/02/mazy4ury.jpg)
(http://img.tapatalk.com/d/14/02/02/umanyny3.jpg)
(http://img.tapatalk.com/d/14/02/02/depa7ybu.jpg)
(http://img.tapatalk.com/d/14/02/02/e3ypazaz.jpg)
(http://img.tapatalk.com/d/14/02/02/amabeve8.jpg)
(http://img.tapatalk.com/d/14/02/02/e9u9azy7.jpg)
I never label my pedals cause I'm lazy and I kind of like when they look like fancy kids toys. I know what the knobs do, I'll never sell them, so that's all I care about. Anyway.
Knobs are purple. I'll eventually replace the 3way switch with something more appropriate. This works for now.
Works and sounds great. I built 2 identical ones (the other one is red sparkle with black knobs). This is about as good as it gets for a delay. :-)
Thanks for designing this thing!
Title: Re: Multiplex with modulation...
Post by: selfdestroyer on February 02, 2014, 12:12:07 AM
That is awesome. Great job on that.
Post by: gtr2 on February 02, 2014, 02:59:13 AM
Well that's a pretty sneaky trick!  Nice work on getting that all in there.
Josh
Post by: lincolnic on February 02, 2014, 05:32:50 AM
The most impressive thing about this is that it doesn't even look like you modified anything. Great work!
Post by: Hangingmonkey on February 02, 2014, 03:53:01 PM
Cool, nice job with the perf.  Im currently rehousing my multiplex with mods.
I was going to ask why you did a separate led for each modulation, but then I thought why not.
Great job!
Post by: greysun on February 02, 2014, 06:27:59 PM
Thanks for the kind words... I did a separate LED for each so that I would know which delay has the modulation going (I can only have one delay at a time with modulation on) - I could listen, but again... I'm lazy. ;-)
