Projects => Build Reports => Topic started by: G.G. on February 03, 2014, 04:19:28 PM
Title: The Enderman (Boneyard II)
Post by: G.G. on February 03, 2014, 04:19:28 PM
Hey Folks,
Here's another "why did I wait so long to make one of these" builds. I was so surprised at how much I like the sound of this. It cleans up really nicely with a slight volume knob roll-off or light picking and the dirt has a lovely grain. Highly recommended if you're looking for a sweet Plexi sound. The only problem now is what to do with the other pedals made redundant by this one, because there are several, and they're ones that I like a lot. This is another one with a Minecraft theme, for no particular reason other than I couldn't think of a good name. Eek, just noticed the pube-like thread of hot-melt glue down on the LED. <sigh> there's always something. . . . .
(http://i.imgur.com/7CaYKDE.jpg) (http://i.imgur.com/LjJ6Th1.jpg)
Title: Re: The Enderman (Boneyard II)
Post by: flanagan0718 on February 03, 2014, 05:46:07 PM
This looks Great! I do have a question for you...Whats with the resistor on the footswitch. Is this for the LED?
Post by: G.G. on February 03, 2014, 05:52:12 PM
yes, that's the CLR.
a Haberdasher board, BTW.
Post by: flanagan0718 on February 03, 2014, 05:53:41 PM
That's a great idea, is it cool if i try it???
Post by: G.G. on February 03, 2014, 05:58:20 PM
haha! Of course!! I think it's how some of the DAM pedals are set up, not my invention at all.  ;D
Post by: flanagan0718 on February 03, 2014, 06:09:38 PM
Cool, way better than soldering to the LED lead and covering with electrical tape. Nice profile pic BTW. haha!
Post by: lincolnic on February 04, 2014, 04:19:18 AM
Wait, the CLR doesn't have to go directly between power and the LED?
Post by: pryde on February 04, 2014, 04:29:09 AM
Awesome Build.
The Boneyard rules. Juice it with an AMZ boost in front and get ready  ;)
Post by: selfdestroyer on February 04, 2014, 04:50:25 AM
Quote from: pryde on February 04, 2014, 04:29:09 AM
Awesome Build.
Agreed, I had a thunderpuss in front of mine for some time. I love how every time I have the Bonyard II on I just can not resist to play a full G chord and feel like Angus Young. lol
Never tried Blue 5mm LEDs for clipping before, whats the Fv compared to Red 5mm?
Awesome looking build by the way, I love the name also.
Post by: G.G. on February 04, 2014, 05:52:35 PM
Quote from: lincolnic on February 04, 2014, 04:19:18 AM
HaHa! I don't understand it either, I just accept it.
I thought that blue LEDs had a higher forward voltage. Actually, I didn't have 4 red so I went with blue. Mine is not super gainy, maybe that's why, but I don't play high gain stuff anyway so it works great for me. Here's a chart I found, not sure if it applies to 5mm LEDs:
http://www.oksolar.com/led/led_color_chart.htm
Post by: selfdestroyer on February 04, 2014, 07:02:17 PM
Quote from: G.G. on February 04, 2014, 05:52:35 PM
Thanks for the link. Very interesting.
Post by: m-Kresol on February 04, 2014, 07:42:30 PM
Nice build!
Haha, first I thought the same: this way the current will drop AFTER the led?!... man, we should both go back to the start for this rookie mistake. Obviously, it's Kirchhoff's first law. It basically states that the current going into a part, also goes out of it. Since the CLR sets a certain current limit, it also has to limit the current through the LED (if we assume that more current can pass through the LED than through the resistor - otherwise the CLR would be nonsense). caution: it makes a difference in voltage, but that doesn't matter at this point
Post by: lincolnic on February 05, 2014, 05:33:35 AM
Quote from: m-Kresol on February 04, 2014, 07:42:30 PM
Nice build!
I still don't quite understand it. If the purpose of the CLR is to keep the LED from burning out (and lowering the brightness in the process), then shouldn't it still be between power and the LED? I'm sure I'm missing something very simple and obvious, but if it's supposed to drop the current going to the LED, I still don't get how it does that if it's after the LED. Current is flowing from power through the LED to ground, no? How does the LED see a lowered voltage if it gets lowered after the LED?
Sorry to hijack your thread, G.G.!
Post by: culturejam on February 05, 2014, 05:57:52 AM
Quote from: lincolnic on February 05, 2014, 05:33:35 AM
Doesn't matter where the current gets limited, as long as it does. As long as the requisite resistance to limit the current happens between the positive and negative rails, the LED will work just fine. So you can put the CLR on the anode, or the cathode, or split the value into two resistors and have one on each side. Same thing.
m-keresol said it right in regard to Kirchoff's Current Law. "The Kirchhoff Current Law (KCL) states that the sum of all currents leaving a node in any electrical network is always equal to zero." http://www.resistorguide.com/kirchhoff-law/
Post by: lincolnic on February 05, 2014, 06:21:28 AM
Quote from: culturejam on February 05, 2014, 05:57:52 AM
Sorry, I'm really having trouble putting the pieces together. I'm not understanding how the LED can see a limited current when that limiting happens after the LED in the circuit. Electrons only flow in one direction, right? So if the resistor is post-LED, why isn't the LED blown up by the full 9V it receives first? How does the limited current go "backwards" to the LED? I think I need a more detailed explanation of how Kirchhoff's Current Law applies here - the math in your link is simple enough, but I'm having trouble understanding how that relates to this circumstance.
I'm really looking forward to the moment where this comes together and I slap myself on the head for not getting it sooner.
Post by: culturejam on February 05, 2014, 07:22:06 AM
There is no "after" in the current flow.
The LED can't conduct until it has a connection from the positive and negative side of the power supply. So it doesn't "get" 9V until the connection to GND is complete. And if there is a resistor in series with the LED (on either side) the amount of current flow is limited (as per Ohm's Law).
So as long the resistance gets in the path of the diode between the positive and negative sides of the power supply, all is good.
Is that working for you at all?
Post by: m-Kresol on February 05, 2014, 11:51:01 AM
I think you also mix up Voltage and current in a way.
The diode's brightness is depending on the current going through it, not the voltage. If the voltage would matter, then there'd be a difference if the resistor is before or after the diode, since the voltage will go down at the resistor.
I'll try to explain the current limiting again (although it's not to easy in english for me):
A resistor is an obstacle to the flowing current, so only a set amount XY can pass. That's the maximum. So, there will not be current flowing from the source to ground. And that amount XY is also the exact amount that will flow through the LED since the resistor sets that limit. It's not possible for the current to be higher trough the LED and then basically "accumulate" in front of the resistor.
Maybe just read up on wikipedia. I guess, the article there is better written than my attempts here.
Post by: Govmnt_Lacky on February 05, 2014, 12:42:45 PM
(http://www.sengpielaudio.com/ohms-law-illustrated.gif)
Post by: G.G. on February 05, 2014, 03:25:36 PM
^^ FINALLY someone puts it in a way I can understand.  :)
Post by: lincolnic on February 06, 2014, 05:58:58 AM
Actually, yeah, I do get it now. Thanks for your patience and explanations!
m-Kresol, you were right, I was confusing voltage and current, which I think is what ultimately hung me up. And don't worry, your English is excellent.
Post by: flanagan0718 on February 12, 2014, 01:59:35 PM
I was finally able to try this CLR method last night and it worked like a charm! Thanks guys.
