General => Open Discussion => Topic started by: Gledison on February 09, 2014, 11:56:14 AM
Title: Constant sorrow: i need advise:P
Post by: Gledison on February 09, 2014, 11:56:14 AM
Hello Folks!
As usual i've found troubles on my way!😫
Normally the standard radial caps were fitting so far in my builds! Now i've built a zsro point delay and the caps are on the edges of the board and of course, i cant close the lid!
I have no low profile caps and i find quite hard to find them in Germany.
My question would be: can i solder the lids of the caps a little longer in order to bend them a little? I've seen people doing tricks with resistors but never with caps!
Thanks for any help!(http://img.tapatalk.com/d/14/02/09/emy7uvyt.jpg)
Title: Re: Constant sorrow: i need advise:P
Post by: m-Kresol on February 09, 2014, 12:02:15 PM
I guess, it should work. I don't see any reason why not.
Where from Germany are you exactly? Where do you source your stuff. I generally have the opinion to source locally to minimize transport times (and shipping costs), but I'm just having the problem that my shipping from musikding.de got lost apparently. It's been 2.5 weeks since they shipped. Also, shipping is really heavy since from germany to austria it's already considered "international". I guess, I will start sourcing from smallbear, etc.
Post by: muddyfox on February 09, 2014, 12:11:56 PM
Hmmm... your board really shouldn't be this high... Why is it tilted? What's underneath that's pushing it up this much?
Post by: Cortexturizer on February 09, 2014, 12:23:21 PM
board mounted pots? is it possible to unmount them, make the lugs shorter, and that way make the board lower? really shouldn't be so high...
Post by: Gledison on February 09, 2014, 12:30:31 PM
Quote from: muddyfox on February 09, 2014, 12:11:56 PM
I have mounted pots and a dpdt switch that is setting the high! :(
Post by: Gledison on February 09, 2014, 12:34:55 PM
Quote from: m-Kresol on February 09, 2014, 12:02:15 PM
Hey mate.
Im located in Mannheim, close to Heidelberg.
Recently I'm ordering from Banzai. Sometimes i order from Tayda but takes 3 to 4 weeks to arrive, plus the lottery with the customs!:S
Post by: muddyfox on February 09, 2014, 12:38:45 PM
Did you remove enough of all the nuts and washers from the dpdt? Sometimes I had issues when I went switch-nut-enclosure-washer-nut, switch-enclosure-washer-nut made it work although it's harder to make it not move arount that way.
Which cap values are the issue here? I have some low profiles and I can send you some. Should reach you within a week...
Post by: hoodoo on February 09, 2014, 12:52:03 PM
Chromesphere, on this forum, also sells low profile caps cheap, look in the buy and sell area  ;)
Post by: RobA on February 09, 2014, 02:54:20 PM
As long as they leads don't contact anything, it's fine to bend the caps over. There are plenty of boards out there that have the caps bent all the way flat, particularly on older designs.
Post by: stevie1556 on February 09, 2014, 04:02:16 PM
Quote from: RobA on February 09, 2014, 02:54:20 PM
Agreed.
I think I've got some low profile caps. If you want a few for the build then let me know as I'm not really using them anymore. I'll need to double check what I've got first.
Post by: Gledison on February 09, 2014, 04:10:56 PM
Thanks a lot guys for the offer.
i removed all the nuts and i will try to remove the protective caps of the pots. maybe i will gain some mm there.
If doesnt work, i will just bend the bloody bastards...
thanks a lot!
Post by: AllenM on February 09, 2014, 04:50:32 PM
Another little trick would be to place some of components on the opposite side of the board so you have more room to bend them to make them lay flat. Not sure if that would help in this situation but I have done it a time or two.
AlllenM
Post by: wgc on February 09, 2014, 05:00:56 PM
You could also remove a bit of the lip on the lid with a file
Post by: pickdropper on February 09, 2014, 05:05:26 PM
Quote from: wgc on February 09, 2014, 05:00:56 PM
Yeah, I've done that before.  I mill it down, but a file would work too.
Post by: icecycle66 on February 09, 2014, 05:12:13 PM
You could put the caps on the other side of the board.
Post by: Gledison on February 09, 2014, 05:46:19 PM
Guys!
The solution was easy!:P
Removing the bloody plastic caps from the pots solved the case!
Thanks for the help and the good tips!!!
Post by: Clayford on February 09, 2014, 08:06:36 PM
I assume you put some tape on the back of the pots to prevent shorting?
Post by: Thomas_H on February 09, 2014, 08:17:22 PM
Quote from: Gledison on February 09, 2014, 12:34:55 PM
Hey mate.
Just to let you know: reichelt has low profile caps a well as musikding.
Post by: Gledison on February 09, 2014, 09:45:02 PM
Quote from: Clayford on February 09, 2014, 08:06:36 PM
Yes mate! i've added a double layer of tape on the back of each pot...and it worked just fine!
Cheers
Post by: Gledison on February 09, 2014, 09:48:47 PM
Quote from: Thomas_H on February 09, 2014, 08:17:22 PM
Hey mate.
Thanks Thomas. i've never heard about this shop...:S
Good tip!
Post by: wgc on February 09, 2014, 11:46:47 PM
I think I built about 4-5 1590a before I discovered low profile electros, I feel your pain
Post by: chromesphere on February 10, 2014, 01:43:33 AM
Its for this reason I pretty much only ever use low profile caps now.  One less factor to worry about ;)
