General => Open Discussion => Topic started by: peAk on February 25, 2014, 11:10:20 PM
Title: 3-D Cad/Model Files of standard pedal hardware?
Post by: peAk on February 25, 2014, 11:10:20 PM
I was thinking today that it would easier to prep for boxing if I could lay everything out in 3-D. Obviously not every single component, I would just do the PCB and the envelope solid of the mounted components, but all the hardware like inputs, pots, dc jack, footswitch, as well as the enclosure.
I don't do a lot of pcb mount stuff because I like the freedom of putting things where I want them and sometimes that depends on the graphics and look I am going for.
Does anyone have any models/parasolids of standard pedal hardware? If not, I could maybe break the calipers out and model some up in SolidWorks or NX and share if anyone is interested? While it may seem tedious, I do this for a living and it would literally take minutes to put one of these assemblies together once you had the standard stuff modeled.
Title: Re: 3-D Cad/Model Files of standard pedal hardware?
Post by: wgc on February 26, 2014, 02:59:17 AM
Diptrace has a library of 3d parts which can be applied to your layout and exported as step assy.  I literally just tried it yesterday on my lunch and pulled into solid works. You can DL Hammond boxes and pull those in too. I may use it to start cnc drilling my boxes.
Post by: mattlee0037 on February 26, 2014, 04:51:13 AM
Google sketchup is what I use. Here's a nice tutorial http://www.youtube.com/watch?v=3VdkvproYIc
Post by: sonarchotic on February 26, 2014, 01:25:25 PM
Power Pop Guy over at BYOC made a pedal builder's vector graphic pack that a lot of guys are using for layouts in Inkscape. Duct Tape Riot over there made a few videos to get people going with it. Not sure if that's what your looking for but you can knock out your graphics and layout with this set-up.
http://www.ontheroadeffects.com/vectorpack/
Post by: peAk on February 27, 2014, 03:23:38 PM
sonarchotic, thanks for that. Vector files are great for graphics and 2D layouts and I will definitely use that stuff but I am talking more .igs, .x_t, .step, .prt, etc.
mattlee0037, I have never used google sketchup, will see what it's about. I mainly use Solidworks and NX.
wgs, I will check that out as soon as possible. It sounds promising! Does putting this stuff in an assembly seem to help with enclosure layout?
Post by: marmaliser on February 27, 2014, 03:33:17 PM
Try here
http://www.tracepartsonline.net/ws/designspark
Post by: rullywowr on February 27, 2014, 04:34:57 PM
Here is a pack of 3D models for components.  I use these with DipTrace for 3D modeling of PCBs but I am sure you can use them with other programs as well.
https://dl.dropboxusercontent.com/u/73135424/3D%20models%20Diptrace/3D%20PART.rar (https://dl.dropboxusercontent.com/u/73135424/3D%20models%20Diptrace/3D%20PART.rar)
Post by: wgc on February 28, 2014, 03:50:21 AM
Just tried an assy for enclosure layout on my lunch break, imported file in sw are a pain at times but not too bad.
I haven't bothered in the past due to others awesome work and drill templates.
I think it will be super helpful and I'm looking forward to doing some cnc drilling.
Post by: alponxo on April 02, 2018, 09:07:41 PM
hi rullywow, could you reupload 3D models forma diptrace?
