General => Open Discussion => Topic started by: Scalymanfish on March 28, 2011, 07:06:05 AM
Title: Best boost for metal
Post by: Scalymanfish on March 28, 2011, 07:06:05 AM
I'm looking to add a small circuit to my guitar build for an on-board boost. So far I'm seeing the Fatpants and the SHO as top contenders. If it doesn't fit in 1590a, it's too big. I'd like to skip a traditional volume knob ala EVH and be able to turn the signal off with the boost gain/volume.
I'm gonna try to lay it all out here for my signal chain on this situation:
BKP Aftermath bridge and Cold Sweat neck, around 15k on the bridge and 12k on the neck.
DIY Tubescreamerish OD
Heavily modded 5150. It's close to an ENGL Fireball in it's tight bass response and the fizz and noise has been reduced dramatically.
Playing tight, thick aggressive metal. Mostly palm mutes and pinch harmonics.
Needs to be low noise, if possible.
Don't need gobs of extra volume.
Looking for an open top end and a tight bottom, but a thick sound with open chording.
Trying to stay away from any kind of low end smudging, high-end brittleness or mid-boosting/notches. Just looking for some "more."
Thanks guys, I appreciate your opinions.
Title: Re: Best boost for metal
Post by: Ang3lus on March 28, 2011, 08:02:13 AM
best boost in general i find is the barber clean boost, it just boosts without taking or adding anything, 20db on tap, but not sure there's a schematic/layout available anywhere, operates on 27v internal voltage i think, only pedal that ever stayed on my board without ever thinking about selling.
Post by: jtn191 on March 28, 2011, 08:17:22 AM
while the SHO is small and low parts count, it doesn't sound like it fits your bill: it's a bit trebly, makes noises as you turn the pot (unless you make a Crackle not ok), and does actually have gobs of extra volume. I happen to like those features, but it seems more classic rock than metal. But try it out if you like what you hear in online demos!
Post by: Bored on March 28, 2011, 11:31:13 AM
I like the Fatpants... or the Spackler (is that right) Mid_Boost from Demeter.
Post by: jkokura on March 28, 2011, 04:20:18 PM
The amz MOSFET booster is what I'm thinking would work for you.
Post by: aziltz on March 28, 2011, 04:51:16 PM
if you want to stick to madbean projects, I would suggest the Spackler for a nice thick mid-boost.  although, I'm personally not a fan of on-board stuff.  You may find that the hassle of the battery and fact that it takes your hand to activate it a bit frustrating.
Post by: maysink on March 28, 2011, 05:10:25 PM
I second the AMZ mosfet (aka 'bean's Thunderpuss (http://www.madbeanpedals.com/projects/Thunderpuss/Thunderpuss_ver1.pdf))
Don't know if it's the perfect metal booster but it's clean with a smidgen of top end sparkle and gets f'ing LOUD!
Post by: Scalymanfish on March 28, 2011, 06:45:27 PM
Going to be fed off the same battery that feeds the piezo buffer and I was just never going to turn it off. I never turn my PA2 off though it's set very low. I'm also looking into a Jackson JE1000 gain booster. Looking at the Thunderpuss scheme with fresh eyes leaves me thinking that may be the solution as well. Nothing fancy, just a hotter signal and easily manipulated for tonal change. I think if I work a highpass set around 50-60HZ into the Thunderpuss(I am really liking that name for some reason), that will be good for me. Keep the unusable mud outta my damn signal. Thunderpuss. ;D
Post by: Myramyd on March 28, 2011, 08:06:10 PM
I use a version of the Thunderpuss (mosfet boost) and I think it's exactly what you are looking for. It's not totally neutral but what it adds is just a touch of "sparkle" or "complexity" (totally subjective terms). Just barely noticeable. Not nearly as much presence or treble as the Slambox or Fatpants. Plus it's small.
The most neutral boost I've played through is the MXR Micro Amp IMHO.
But, if you are sharing a battery, you might want to check current draw. Just to make sure...
J
Post by: Scalymanfish on March 28, 2011, 08:35:39 PM
Can I run the Thunderpuss on 18V? Are there benefits to be had?
Post by: thatirishsob on March 28, 2011, 09:41:22 PM
Did you mod your 5150 yourself or send it out?
Post by: Scalymanfish on March 29, 2011, 12:52:48 AM
Modded myself. There's no way I'm paying $400 for a handful of components that I'll end up fine tuning anyways. ;D
Have a bias mod, mid sweep, the noise reduction from the XXX/JSX/Rockmaster Pre installed(which is exactly what FJA does. It's a 3 component mod. 2 diodes and either a fixed or a pot), general revoicing of the input and gain stages and a conversion of the rhythm channel into a second lead that isn't nearly as stiff or thick as the original lead, which I play rhythm with. ??? I use a fendery DIY tube pre for cleans because there's no use pretending the 5150 will ever have a great sounding clean without major sacrifice or surgery. The first unit in my rack is dual input so I use a buffered ABY pedal circuit to switch between the clean pre and the 5150 pre. Best set up I've had yet and it didn't cost a fortune like my former ENGL head.
Post by: maysink on March 29, 2011, 03:29:21 AM
Quote from: Scalymanfish on March 28, 2011, 08:35:39 PM
Absolutely. I did not notice any major difference but I mainly ran it 18v so...
Post by: bigmufffuzzwizz on March 29, 2011, 02:03:33 PM
Quote from: aziltz on March 28, 2011, 04:51:16 PM
This is the one at freestompboxes.com right?
Post by: irmcdermott on March 29, 2011, 02:31:39 PM
Quote from: bigmufffuzzwizz on March 29, 2011, 02:03:33 PM
you can buy that board here. the doc is over in the "Projects" section of the main page.
Post by: Scalymanfish on March 31, 2011, 01:27:56 AM
I have found midboosts useful in certain situations, but this one's gotta be pretty flat. BKP Aftermath plus Wenge neck and body = mid city. I think I may be looking at the Fatpants here for this one as a final decision. Extra sparkle up top and some bass if it's needed and I've got the tip on it being very low noise so as long as that holds up, should be in the land of good tone. Anyone care to comment on Fatpants and noise?
Post by: pandadandan on March 31, 2011, 02:29:20 AM
Bigger than you possibly wish for, but the Boss FZ-2 is a great boost for metal.  It has a 30db flat-response boost option in addition to the two fuzz options.
Post by: Myramyd on March 31, 2011, 03:42:28 AM
Also, if you are throwing that boost in front of an already high-gain situation, it's not going to do anything but create mush. At that point if you need a clean boost to make the volume louder, it would either need to be after the gain pedals or even in your FX Loop if your amp is also high-gain. Otherwise you won't boost volume at all.
J
Post by: Scalymanfish on March 31, 2011, 06:25:35 AM
Well I'm not a stick everything on 11 type of guy. ;D  I just like to have my levels "correct" going in and a little shaping if possible on my guitar. A lot of what I did to that 5150 was bleed off some gain between stages to take care of the fizzies and it's overcompressed nature. I'm a nut about hitting things the way I want. High gain, yes, but not mushy in the slightest. Crispy. Like this(it's tame): http://www.youtube.com/watch?v=F7jfigffl1U
So noise on the Fatpants... Anyone have experience to share? Good? Bad? OK, but manageable? Anyone have a Fatpants AND a Thunderpuss?
Post by: maysink on April 01, 2011, 04:30:05 AM
IMO, both the fatpants and thunderpuss are fantastic boosts w/ some top end sparkle. I found the FP to have slightly more sparkle and the TP to have more volume on tap. This is completely subjective but the the FP's sparkle struck me as being warmer.
I've only built the original, one-knob FP as I'm anxiously waiting Brian's 100% original mod to the new 2-knob FP (as mentioned here (http://www.madbeanpedals.com/forum/index.php?topic=716.0)).
I once read the original echoplex preamp added some kind of super-slight phasing to its boost...
I just re-read this and have no idea if it helps! Good thing they're both inexpensive boards!
Post by: gtr2 on April 01, 2011, 12:13:49 PM
I haven't experienced noise with the fatpants.  But I don't think I would use it in the way you are contemplating.  I just don't think you're going to get the tone your after with this.  While I like supporting Bean I'd consider the AMZ Mosfet Booster instead.  I think Jacob suggested this already.  Here's a link...
http://www.muzique.com/schem/mosfet.htm
He sells fabbed boards for this project as well.
EDIT: This is Madbeans Thunderpuss board..  I feel silly.
Josh
