Projects => Build Reports => Topic started by: juansolo on April 02, 2014, 03:26:26 PM
Title: The Jetalizer
Post by: juansolo on April 02, 2014, 03:26:26 PM
A commision for 4000mile Phil (as opposed to 400yd Phil...), this is the Warm Jetalizer, a multi that's essentially a board in a box.
Everything about it was awkward due to the size of the 1550G enclosure. Not to mention there are things I know now that I didn't before. For example, the jacks should have gone on the back so I could get the stomps further apart. As it is, they're a little tight. But you don't really figure this stuff out until you actually do it.
Still it's all in there solidly and it sounds good! In there is the Bean Zero Point DD and Stagefright, a Rusty Sheriff, a Apis based true bypass Klone, and a Grind Rotten Compressor.
(http://juansolo.demon.co.uk/stompage/images/jetalizer-o.jpg)
(http://juansolo.demon.co.uk/stompage/images/jetalizer-i.jpg)
Title: Re: The Jetalizer
Post by: Jabulani Jonny on April 02, 2014, 04:07:55 PM
This is a great set!  It's a lot like a build I'm planning right now.
Post by: raulduke on April 02, 2014, 04:22:49 PM
That. Is. F*cking. Awesome.
Clean as a whistle dude  8)
Post by: billstein on April 02, 2014, 04:34:42 PM
Wow! Your attention to detail is amazing, for example those red wires at the bottom all on the same angle.
Post by: juansolo on April 02, 2014, 04:39:51 PM
Quote from: billstein on April 02, 2014, 04:34:42 PM
lil bit of OCD...
Post by: ch1naski on April 02, 2014, 05:49:43 PM
Beautiful, Juan. Love the staggered pcb layout
Curt.
Post by: peAk on April 02, 2014, 05:57:21 PM
Incredible!
So do you actually do all your wire measuring prior to it going in the box or do you actually trim and fix wire lengths as needed once boxing? Please tell your secrets.....
I just can't achieve this neatness  :'(
Post by: Jabulani Jonny on April 02, 2014, 06:01:38 PM
Oh, and what do you use for the solid core bare wire on your pots?
Post by: juansolo on April 02, 2014, 06:22:08 PM
Quote from: Jabulani Jonny on April 02, 2014, 06:01:38 PM
It's 0.6mm Eagle Equipment wire (bare copper). All the boards are essentially mounted by the pots/switches using it. Sometimes there'll be foam pads on the back of the pots for additional support. They're not going anywhere.
You can't get the wire any more annoyingly. I think we've got about 500m left, then we need to find an alternative.
Quote from: peAk on April 02, 2014, 05:57:21 PM
Incredible!
Wire will be soldered to the board over long and I have an idea where I'm going to route it. Board goes in and the the other end of the wires are trimmed to length and attached.
Post by: jubal81 on April 02, 2014, 06:26:06 PM
Mind blown. Board in a box, indeed. No way it should be that clean inside.
Post by: GrindCustoms on April 02, 2014, 06:28:51 PM
The bar have now been set really high, i do like this! 8)
Post by: nzCdog on April 02, 2014, 06:59:34 PM
Always a pleasure to see your builds JS 8)
Post by: Leevibe on April 02, 2014, 07:02:52 PM
Beautiful! Tons of skill to make such a complex build look so clean and "simple."
Post by: davent on April 02, 2014, 10:37:43 PM
That baby's on fire! Always so much to be gleaned from your work. Great build, you are a very patient man!
Post by: lincolnic on April 03, 2014, 04:19:55 AM
This one raises the bar, even for you!
Though I have to say, if you're going to design a pedal around Here Come the Warm Jets, I'd expect to see a WEM Project V in there...
Post by: juansolo on April 03, 2014, 07:41:39 AM
Lad I built it for is a big fan and wanted to use the art on something else I built for him and it didn't work. Fit just nicely here though :)
Post by: Bret608 on April 03, 2014, 02:58:22 PM
I thought the same thing but think the Eno album cover is still an awesome idea!
Post by: lincolnic on April 04, 2014, 04:00:19 AM
I'm just poking fun. It's still a great image.
Post by: she sells sea shells on April 04, 2014, 08:19:05 AM
very nice job dude!
Post by: wgc on April 05, 2014, 12:40:33 AM
Awesome, love the stagger!
Post by: pickdropper on April 05, 2014, 01:42:51 PM
That is one of the nicest wiring jobs I've ever seen.  Fantastic work.
