General => Open Discussion => Topic started by: sp3k on April 14, 2014, 04:31:00 PM
Title: splitter pedal
Post by: sp3k on April 14, 2014, 04:31:00 PM
Hi! A friend asked me to build him a tiny splitter pedal (1 in 2 outs). He pays in a 2 piece band, he splits his signal to a guitar and a bass amp. He doesn't want a switch or anything, even prefers if it can be passive.
Do you think a simple passive wiring with no components (just jacks and wire) will work fine? should I put a buffer on the thing?
Title: Re: splitter pedal
Post by: midwayfair on April 14, 2014, 04:41:58 PM
Passive splitters seriously suck. Just ... don't do it.
Post by: sp3k on April 14, 2014, 04:50:30 PM
do you think adding a klone buffer to the input would be enough so it doesn't suck so much?
Post by: Clayford on April 14, 2014, 06:17:33 PM
Yes.
Look at the oshpark shared section.
http://www.madbeanpedals.com/forum/index.php?topic=10869.0
Specifically you want irmcdermott's Dropin board for the Ernie Ball VP Jr.  You'll ignore the Led's since they're there for lighting effect on the volume pedal except maybe one, to prove the unit is powered. Passive splitters suck, steal tone, cause impedance problems, volume loss etc.
You might be able to perf or vero something out from the schematic. It's two Klon(e)buffers one for each side. It works perfectly.
Post by: sp3k on April 14, 2014, 06:43:58 PM
I think I'll just use veroboard, I've done lots of veroboard pedals, and for such a small thing I think is not worth spending the extra cash on a pcb.
So one buffer for each output, or just an input buffer?
Post by: Clayford on April 14, 2014, 06:50:35 PM
https://www.dropbox.com/s/neyoxrjhc9lu7mw/Buffer%20Splitter.pdf
There's the schematic
