Projects => Build Reports => Topic started by: rullywowr on May 09, 2014, 02:50:02 AM
Title: Rollin' in my 'six-fo', with Timbo
Post by: rullywowr on May 09, 2014, 02:50:02 AM
Here is a Timmy in a dormant purple powdercoated enclosure with a laser etched "Nintendo" theme.  Neutrik jacks, BLMS DC jack, and purple flat top UV LED.  A couple of carbon comps in there, strategically placed (meaning I had those values on hand that fit this build).  :)  This build features one of my latest PCB projects, the "Six-Fo" switcher.  The 'six-fo' makes it super easy to add intelligent switching to any pedal project, using low-cost and off-the-shelf components.  Assembly is also quick in less than 5 minutes and includes preprogramed uC.
(https://dl.dropboxusercontent.com/u/73135424/Timmy/Timmy4%20(Medium).png)
(https://dl.dropboxusercontent.com/u/73135424/Timmy/Timmy3%20(Medium).png)
(https://dl.dropboxusercontent.com/u/73135424/Timmy/Timmy2%20(Medium).png)
(https://dl.dropboxusercontent.com/u/73135424/Timmy/Timmy6%20(Medium).png)
(https://dl.dropboxusercontent.com/u/73135424/Six-Fo/64-1%20(Medium).png)
(https://dl.dropboxusercontent.com/u/73135424/Six-Fo/64-6%20(Medium).png)
Timmy sounds, well...like a Timmy.  Great circuit Paul C. designed and very versatile - has minimal coloring of your tone.  One of my favorites.  It sounds just like my real Timmy, maybe even a bit better.  Build one and then buy a real one...err...or the other way around.  :)
The 'six-fo' switcher is a result of a lot of blood, sweat, and unsigned long variables.  It will be available at rullywow.com in the next day or so.  I will post a link below to a separate thread regarding the complete details.  It is a microcontroller relay PCB which mounts right on a momentary stomp and "remembers" if it was on/off (memory feature can be disabled).  With a plain vanilla L78L05 it draws less than 3mA in idle (mostly quiescent current from the reg - circuit draws under 1mA) and has a new, very advanced debouncing algorithm - meaning you can use it with straight-up any momentary switch (works excellent with Tayda and BLMS $2.00 switches).  The ratings of the components are in the neighborhood of way over 100,000 stomps...and it does it all without any mechanical clicking.  I like the ease which it allows you to mount the PCB while taking care of your switching/wiring/powering duties - all in style!
Title: Re: Rollin' in my 'six-fo', with Timbo
Post by: the3secondrule on May 09, 2014, 03:23:05 AM
That's dope.
Do want
Post by: mattlee0037 on May 09, 2014, 03:39:37 AM
Must use everywhere.
Post by: Leevibe on May 09, 2014, 03:51:15 AM
Very cool!
Post by: selfdestroyer on May 09, 2014, 04:26:43 AM
Awesome Rully. I will definitely give them a try. I was a bit confused at first cause I though Timbo the forum member was involved in this.. lol
Post by: LaceSensor on May 09, 2014, 10:57:25 AM
cool switch PCB
Does it use latching or unlatched relays?
Post by: micromegas on May 09, 2014, 11:01:01 AM
Quote from: LaceSensor on May 09, 2014, 10:57:25 AM
cool switch PCB
I think the Takamisawa AL5WN-K is latching type
Post by: rullywowr on May 09, 2014, 02:16:38 PM
Thanks guys.  It uses 5v latching relays (AL5WNK) by Fuji/Takamisawa or compatible mostly for power savings.  I have a large amount of these relays on hand and will offer to include them with the PCB.
Post by: LaceSensor on May 09, 2014, 02:39:49 PM
take my money
Post by: G.G. on May 09, 2014, 03:30:45 PM
Damn, sir! The switch assembly alone is worth its own thread. Excellent work!!! Love the enclosure treatment!!!
Post by: alanp on May 09, 2014, 05:59:09 PM
Has it been FCC tested for compliance with regulations? ;)
More seriously, that's a pretty sweet solution. Do those cheap SPST momentary stomps need de-bouncing?
Post by: rullywowr on May 09, 2014, 06:15:29 PM
Quote from: alanp on May 09, 2014, 05:59:09 PM
It's only designed to run off a 9V battery (of course).  If someone builds it into a project with a 9V adapter then it's up to them to get FCC approval before selling their pedal  ;D ;D ;D  (/sarcasm)
Thanks Alan.  Yes, the cheap SPST momentary stomps are especially bouncy (boiiing!).  After a lot of trial, error, and development, I have effectively debounced the switch input using an "advanced proprietary debounce algorithm" (wow that sounds geeky!).  This is a crucial aspect, as space is very limited on the PCB for using a debounce filter network/schmitt trigger setup.  Using a regular "debounce delay" routine doesn't work well for these momentary stomp switches in particular.  This will work for just about any momentary stomp or momentary push button you can find.  Tayda and BLMS momentary stomps are what these are designed for, although if you want to be a "baller" you can drop $9USD on a Carling 110-PM.
Post by: snz728 on May 09, 2014, 07:30:36 PM
Would this work with a wah to stop the clacking or would it turn it on/off too easily?
Post by: rullywowr on May 09, 2014, 07:34:49 PM
Quote from: snz728 on May 09, 2014, 07:30:36 PM
Unfortunately, with the momentary stomps I have tried it would probably turn off too easily.  There is no "click" or spot on the stomps to prevent you from turning it off.  If you were able to find a stomp with a click in it...that would work.  Or I suppose if you installed a piece of hard foam/rubber and adjusted the height to trigger at the right spot it could work.
Perhaps another DIY project is in the works for a replacement wah pad where it turns the wah on just by putting your foot on it.  I have seen some similar commercial pedals with this feature.
Post by: selfdestroyer on May 09, 2014, 08:22:54 PM
Quote from: rullywowr on May 09, 2014, 07:34:49 PM
I was looking into that a few months back when I did a repair on my aunts Morley mini wah but it seems like all the info I can find on the "turns the wah on just by putting your foot on it" was only optical wahs. Ill have to dig around some more.
Post by: rullywowr on May 09, 2014, 08:38:48 PM
Opticals have this feature (ie: Morley) because they have a spring loaded treadle.  When your foot comes off of it, the treadle goes all the way back and moves the optical light plate into a region where bypass is triggered.
I think something like pressure sensitive resistors could work nicely if they were embedded in the rubber (or under the rubber).  Something like these are usually less than $10:
(http://www.trossenrobotics.com/shared/images/PImages/S-20-1000-FS15.jpg)
A microcontroller could easily read the threshold value and trigger the true bypass relay, like on the 6-4.  A simple resistor divider trimmer or knob can adjust the sensitivity.
Post by: selfdestroyer on May 09, 2014, 08:46:48 PM
Wow, very interesting. This would be a fun project. I will have to read up on the pressure sensitive resistors.
