Projects => Build Reports => Topic started by: LaceSensor on May 10, 2014, 11:32:18 AM
Title: Final version of Lovetone Doppelganger clone
Post by: LaceSensor on May 10, 2014, 11:32:18 AM
Finally got round to verifying the 2.1d boards
Had the case drilled for months! Just time. I can now order these, as Jacob (JMK) did the gerbers for me ages ago :)
Sounds and functions perfectly, and now the wiring is much neater and the silkscreen is perfect, thanks Jacob.
(http://i1178.photobucket.com/albums/x374/LaceSensor1/IMG_0025_zpsaa9e8cad.jpg)
(http://i1178.photobucket.com/albums/x374/LaceSensor1/IMG_0027_zps554983fe.jpg)
Title: Re: Final version of Lovetone Doppelganger clone
Post by: jubal81 on May 10, 2014, 02:14:07 PM
Ridiculously impressive. That's a real feat.
Post by: jimilee on May 10, 2014, 03:10:40 PM
That's fantastic
Post by: wgc on May 11, 2014, 01:30:31 AM
Killer!
Post by: slimtriggers on May 11, 2014, 02:21:20 AM
Man, that's cool!
Post by: lincolnic on May 11, 2014, 04:17:48 AM
Gorgeous!
Post by: pickdropper on May 11, 2014, 04:32:06 AM
That is fantastic.  Great build.
Post by: LaceSensor on May 11, 2014, 11:32:23 AM
Thanks guys
Post by: Leevibe on May 11, 2014, 12:57:04 PM
Wow!
Post by: Guitafuzz on May 13, 2014, 04:19:29 PM
Awesome Build!!  What type of enclosure is that?
Post by: wgc on May 13, 2014, 04:22:34 PM
awesome, cool to see someone using the anchor tabs on the pots
Post by: LaceSensor on May 13, 2014, 04:33:53 PM
Quote from: Guitafuzz on May 13, 2014, 04:19:29 PM
1790ns size
its a hammond 1590XX
142 x 120 x 40 mm
Post by: soggybag on August 17, 2014, 07:04:34 AM
Which pots and toggle switches did you use? I'm working on one of the boards right now, and I'm wondering about the heights of these since they are board mounted.
Post by: m-Kresol on August 17, 2014, 08:54:55 AM
I finished mine late yesterday night (be ready for the build report) and I used 9mm pots (the ones with the hooks on the side to go through the bigger holes in the pcb) and regular switches like these (http://www.musikding.de/Kippschalter-SPDT-1x-UM-flacher-Hebel). At first I had some problems with small height differences, but taking the first nut of the switches solved it.
Post by: LaceSensor on August 17, 2014, 12:36:24 PM
Quote from: soggybag on August 17, 2014, 07:04:34 AM
9mm pots by alpha
Tayda/Sci style toggles...
Post by: mmlee on August 18, 2014, 07:51:39 AM
Great stuff, I'm going to have to try this lovetone stuff soon. Is that Doctor Tweek shielded wire?
Post by: cooder on August 19, 2014, 03:04:49 AM
Fantastic! What everyone else said...  8)
Post by: LaceSensor on August 21, 2014, 03:44:47 PM
Quote from: mmlee on August 18, 2014, 07:51:39 AM
Yes
Post by: blearyeyes on August 22, 2014, 02:42:08 AM
Just wanted to chime in and say that after I got my board finished I hooked it up and played Lace's YouTube video comparing it to the Original and this one sounds identical. I'm really impressed. Great job you guys!
Now to get it boxed...the bane of my pedal building existence...
