Projects => Tech Help - Projects Page => Topic started by: kost2112 on May 22, 2014, 12:41:22 PM
Title: problem with grafic fuzz
Post by: kost2112 on May 22, 2014, 12:41:22 PM
Hi all,
i have an issue with one of my pedals, ehx grafic fuzz, so if anyone could help me i'd be glad.
When the pedal is switched off the signal passes through normally, but when i press the button of the ehx, the signal does not pass at all although the LED is on, so i guess there is no problem with the current that makes the pedals work.
I could upload a photo of the pcb if you think it could be helpfull.
Thanks in advance.
Title: Re: problem with grafic fuzz
Post by: m-Kresol on May 22, 2014, 04:35:26 PM
A picture WOULD be helpful indeed.
from the info you gave us, it's nearly impossible to say something based on facts. I can only guess: it is possible that the power supply cable to the PCB is broken/solder joint ripped out. Same would be possible for the in- or output cables from the switch to the PCB.
cheers
