Projects => Tech Help - Projects Page => Topic started by: Rich_S on May 26, 2014, 03:04:21 AM
Title: Road Rage for 18 V Dirt Box?
Post by: Rich_S on May 26, 2014, 03:04:21 AM
I have a Catalinbread Dirty Little Secret that I want to try at 18 volts.  I'm told they sound great that way.  Rather than tie up two outputs from my PP2+, I was thinking of building a Road Rage to stick between a normal 9-volt supply and the DLS.
I see the 15-volt output from the Road Rage uses its own regulator.  However, I want to run it at 18 volts, without the extra regulator.  Is the 18-volt output from the charge pump sufficiently regulated that it will power a dirt box cleanly?
Title: Re: Road Rage for 18 V Dirt Box?
Post by: alanp on May 26, 2014, 03:17:54 AM
15V is still worth trying. I suspect 18V unregulated will be noisier, but not hugely so.
