Projects => General Questions => Topic started by: garfo on May 27, 2014, 10:52:32 AM
Title: stereo pot
Post by: garfo on May 27, 2014, 10:52:32 AM
Hi, I'm looking for a replacement for the alpha stereo 50k pot.I need a 50 k pot with a longer bush to build directly on basses and Guitars that don't Go with pickguard.Any suggestions?
Title: Re: stereo pot
Post by: jkokura on May 27, 2014, 05:59:57 PM
I think Fender makes one of those. You should check at Allparts and the other guitar supply shops.
Post by: selfdestroyer on May 27, 2014, 07:39:04 PM
This may help
http://www.soselectronic.com/a_info/resource/a/pdf/pom_pos.pdf (http://www.soselectronic.com/a_info/resource/a/pdf/pom_pos.pdf)
I think you are looking for the Alpha RV122F series
Wrong
Ill keep looking..
RV16A01F-10-XX should work for you but you will need to find the shaft length you will need where the XX is.
Post by: garfo on May 28, 2014, 09:28:46 PM
The problem is not the shaft itself, it's the bush.That one is 6.5, which is pretty standard.I need 9/10.I think I've found two products, one is from Vishay and the other one is from Bourns.The vishay one is perfect but it expensive, 16 euros each one.I'll have to decide.
Thank you
