Projects => Tech Help - Projects Page => Topic started by: jighead81 on July 06, 2014, 03:34:48 PM
Title: Nutron II LED "off-time" *FIXED!*
Post by: jighead81 on July 06, 2014, 03:34:48 PM
This thing sounds great, but the LED is staying off for more time than the "on-time". Is this normal? I've tweaked the trims with no luck, swapped out all the IC's with known working chips, used different charge pumps, and checked all traces.  Could it be the 2n4401?  It just seems like I have phasing, then it's off for more time then it's on.
(http://img.tapatalk.com/d/14/07/06/sapady2u.jpg)
Title: Re: Nutron II LED "off-time"
Post by: jighead81 on July 06, 2014, 06:34:24 PM
Switched out 2n4401, no luck.  But, when I hooked up the LED for the blinking indicator, both LED's just stay on, no more blinking, just on.  Weird
Post by: GrindCustoms on July 06, 2014, 06:53:45 PM
IIRC, TR1 sets the maximum depth and TR2 the maximum brightness, they should'nt have an influence on the Lit up/Lit down of the LED.
Couple time ago i figured out that the LFO in this circuit was too «complicated» for what it really needed to be... so i now stick a daughter board with a simplier LFO with no trimpots and it works flawlessly everytime.
Sorry, this does'nt help a lot...
Post by: GrindCustoms on July 06, 2014, 06:55:06 PM
I see that you used a LT1054, is your pin1 lifted?
Post by: jighead81 on July 06, 2014, 07:00:37 PM
No it's not lifted, I tried the 7660, max10"", and same problem.
I couldn't get TR1 to do anything, but it sounds like that's not my problem anyway. Gonna start reflowing some more joints, just to make sure, thanks Rej
Post by: midwayfair on July 06, 2014, 08:39:18 PM
Quote from: jighead81 on July 06, 2014, 07:00:37 PM
You *must* lift pin 1 of the LT1054. Separate issue, obviously.
Post by: jighead81 on July 06, 2014, 08:52:02 PM
I just had the LT1054 in there for a sec while I was troubleshooting, but took it back out.  Tried reflowing everything and still have the pause.
Post by: alanp on July 06, 2014, 11:09:49 PM
My guess would be a wrong resistor value somewhere.
Post by: Haberdasher on July 06, 2014, 11:15:41 PM
Quote from: alanp on July 06, 2014, 11:09:49 PM
this.
iirc, i could adjust mine to stay off very briefly or longer.  sounds like a wrong value somewhere.
Post by: jighead81 on July 06, 2014, 11:57:10 PM
Thanks guys, that's my next little journey for this.  Hab, how were you able to adjust that?
Post by: Bret608 on July 08, 2014, 02:24:20 PM
Hey man, I'm trying to check your resistor values out for you. I'm working on one of these too so happen to have the build doc handy. I can't see every value (R34, R35, and R36 in particular), but things mainly seem to check out. I would just say double check those as well as what you have for R38 (which I can't make out clearly). Also, on R30, make sure you don't have 100k in there instead of 10k. That fourth bank looks like it could be orange but I can't tell for sure.
Post by: Haberdasher on July 08, 2014, 03:22:11 PM
Quote from: jighead81 on July 06, 2014, 11:57:10 PM
well it's been a long time, so i don't remember exactly.  i just followed the advice from this post by bangerang101
http://www.madbeanpedals.com/forum/index.php?topic=6749.msg60231#msg60231
Post by: jighead81 on July 08, 2014, 11:49:56 PM
Bret, I couldn't find a bad resistor anywhere.
Bad cap maybe? When I try to hook up the  rate indicator LED it stops blinking and stays lit, the yellow one does the same then. I think I'll swap out the diodes next just to make sure about those, and socket them.
Post by: Bret608 on July 09, 2014, 02:34:03 PM
Something else I wondered...would using tantalum caps have any impact?
I wish I had more to offer you here...hang in there!
Post by: jighead81 on July 09, 2014, 06:51:18 PM
I think I saw where Brian used electros, and Rej used tants?....so I thought I'd try the ones I had.  My next plan is a reflow party, and the whole board is invited.
Post by: GrindCustoms on July 09, 2014, 11:09:13 PM
Are you using a TL072 for the LFO opamp?
Post by: jighead81 on July 09, 2014, 11:35:45 PM
I've got all TL072's in there now. I've swapped out different ones because some were from Tayda and I was worried about them.  I've even popped in some TL062's to try
Post by: jighead81 on July 10, 2014, 01:39:36 AM
Well, I started the reflow party, about halfway into it I noticed a little teeny tiny "c" hair of a bridge.  I think that's what it was anyway.  I reflowed it and cleaned everything, socketed the diodes and put new ones in.  BOOM, working great and sounding amazing.
Reflowing and looking for the smallest bridge seems to always help me successfully complete etched boards.  I also learned that I can get away with using a lot less solder and still get a nice fillet.  ;D
Thanks so much for your help guys.  I'm really excited with this being my first phaser.  I took a break from troubleshooting this the other day, and built a demo tape fuzz, (also etched by haberdasher), and that bad boy fired up first time.  Hab does great work and I highly recommend hitting him up for your etching needs.
Title: Re: Nutron II LED "off-time" *FIXED!*
Post by: Bret608 on July 10, 2014, 02:07:55 PM
That's great! I know what you mean, I was able to create a massive bridge when I was populating my Nutron. Glad I saw it when it happened! Now I just need to order some LDRs...
Post by: Haberdasher on July 10, 2014, 02:36:23 PM
Quote from: jighead81 on July 10, 2014, 01:39:36 AM
awesome man, glad you figured it out.  this is a really nice phaser.
i think it is easier to spot a solder bridge on the black material!
and thank you for your comments, i appreciate it.
cheers
Post by: jighead81 on July 10, 2014, 04:04:22 PM
Bret, I bought 40 LDR's from Tayda just to make sure I could match some, I've got about 8 more that are very close and I can send you the 6 for this project. No charge just let me know
