General => Open Discussion => Topic started by: copachino on July 19, 2014, 04:26:59 PM
Title: size on 1590A
Post by: copachino on July 19, 2014, 04:26:59 PM
im under a englishman on a 1590A enclosure but im not so sure how many space i have on a 1590A enclosure, my pcb its 1.30x1.09 inches, but since i dopnt have a 1590A enclosure im not so sure about the size,  what are the space on the 9mm alpha  pots?? i have 0.15 inch spacement, and 0.1 for the spdt switch
Title: Re: size on 1590A
Post by: davent on July 19, 2014, 05:02:13 PM
To check sizes there's a proper sized template you can print out at the end of this document.
http://www.madbeanpedals.com/downloads/BabyBoardGuide.pdf
Post by: copachino on July 19, 2014, 06:47:24 PM
Quote from: davent on July 19, 2014, 05:02:13 PM
i know the outside measuraments, but i was hoping to get the inside, i have seen beans baby boards to have also 1.30 inches but im not sure if they fit on every 1590A on the internet, there are many enclosures called like that
Post by: davent on July 19, 2014, 07:31:51 PM
Page 17 of the document, you'll have to measure a printout... or Hammonds datasheet, if you're using a Hammond.
http://www.hammondmfg.com/pdf/1590A.pdf
