as a mechanical engineer, i been seeing some laser etched enclosure even they are from professional machine, i have a module for stepper motor from an old cnc project i maded, i still have some pieces and stuff, so i will only have to buy some pieces like the laser, and some aluminium structure, for that, i have in OSH park shared the drivers and the module  for the drivers, and Arduino board will be the interpreter from the program and the stepper drivers, drivers are able to make 1/8 step from the motors so i have 200 step motor(200 step per 360°), giving the main resolution to 1.8°, but the driver its able to make 1/8 so the total rosolution will be 0.225°, that its an insane resolution por DIY cnc machine, stepper are nema23, 2.5A per fase, machine will be 3 axis and only be using 2 axis in the laser engraver mode, but i want to leave 3 axis to just change the laser for a dremel and use it for machine engraver builds(probable pcb prototyping)its going to be a long journey and it will be taking months to complete, but if someone its interested i can post updates, source code, and plains of the machine, would it be any interest over here??
				You may be able to find that type of info on the web already.  There have certainly been folks who have made their own laser engravers.
It could be a cool project.  But make sure you design proper airflow and ventilation into it.  It's very important, especially if you will be using it to cut acrylic.  It's important for two reasons:
1.)  The fumes can get really unpleasant
2.)  It's a severe fire hazard with it.
At the very least, you'll need an air compressor to pull air across the bed while cutting.  I just got done helping with the installation of the FFX laser engraver and we had to run ducting with a dedicated fan that's always on, AND an air compressor for when cutting.
				do you know a good cam program based on gcode to run th engraver??, i need some info here(since i only used mechanical cnc cads for gcode), i will serch some infor here of users with his engravers, will try to make a full project for those fo are willing to make one of this, as i say im aming a really insane(for DIY) resolution machine, i need to machine some acme threads, for the job to make it better and i have some ball bearings with guides too.
				Quote from: pickdropper on July 21, 2014, 04:44:00 PM
i will noy only need a compressor for the job but also a pump whrn the machine its on CNC mode, for the cooling of the parts, and also the cmompressor will be needed to extract fumes and all other waste...
				That's all up to how you configure the drivers.  The laser we purchased has a standard windows printer driver, so I run it from Adobe Illustrator.  Corel Draw is another popular one.
Laser engravers are usually different than CNC engraving machines; they don't use gcode.
My advice is to do a lot of research before jumping in.  If it's not done right, it can be a severe fire hazard.
				Quote from: copachino on July 21, 2014, 05:06:25 PM
You are going to water cool the parts while cutting?  Like a water jet machine?
I think you are talking about a different type of laser than I am.  We purchased a CO2 based laser, which is good for etching powder coat off of boxes, but is not capable of etching into metal.  It sounds like you are talking fiber or yag lasers.  The heavier duty industrial machines that cut metal are the only thing I could think of that would require liquid cooling of the parts being cut, and I am not sure I've ever seen that.
There are water chillers for keeping the machine cool (and maybe blowing colder air), but that's a bit different.
				Building something like this is beyond my current capabilities but I am totally interested in seeing updates and watching how this comes together.
Quote from: pickdropper on July 21, 2014, 05:10:40 PM
I think he is talking about a coolant pump for doing more conventional 3-axis spindle cutting/engraving in addition to it's 2-axis laser capability.  Sounds like a versatile little machine being built here.
				Quote from: chuckbuick on July 21, 2014, 07:12:01 PM
Versatile yes, but it might be better served building them as two separate machines.  I think having a bunch of liquid being sprayed around the laser optics would be less than optimal.  But perhaps he has a clever way of protecting the laser while the 3-axis spindle is doing its thing.
We have a 4-axis CNC as well as a laser engraver at work and they are far different machines.  At this point, I can't imagine combining them.  It doesn't mean it can't be done, but I am just not seeing it at the moment.
nono, i would be 3 axis machine, but, with build in code for a CNC machine using a dremel for cutting pcbs and stuff like that, and a removable head with the laser fot the etching, its like haveing 2 in 1 machine, a laser engraver and a CNC machine, i believe that laer engraver also must use gcode, otherwise stepper and servos would understand the code, i will make a little reserch of that, as i said its gonna take months to complete this little monster and probably start on wood machine to debug and the aluminium structure to make it more suitable for hard jobs on enclosure(CNC part) and pcbs
				Quote from: pickdropper on July 21, 2014, 07:17:19 PM
thats because your machine are professional grade CNCs and professional engraver, its would be hard to move that big CO2 laser on that, or the head on the 4 axis CNC, but in a small homemade machine you can make the modules(the splindle and the laser to removable so you will use only the hardware as CNC for the two jobs, but i cant be a pain in the ass too... i had built a CNC with 4 axis before a 2 axis engraver its like possible based on that, but i really think corel must use certain gcode prosses to make the engravement
				Well, it sounds like you have a good idea of how you want to do it.  Best of luck with it.  I'm looking forward to seeing the results!
				Or you can go the really cheap route:  http://www.instructables.com/id/60-Laser-Engraver--Cutter/
Seems like a really good way to hurt somebody.
				Quote from: mgwhit on July 21, 2014, 09:01:37 PM
Or burn your house down.
				Quote from: pickdropper on July 21, 2014, 09:04:11 PM
hahaha that a good way to do it.. but i will try before using a CO2 laser with a common laser and a power module to burn in wood or paper, after that  will try co2 maybe jajaja
				Quote from: copachino on July 21, 2014, 09:31:02 PM
I honestly wish you the best of luck.  Please be careful.
				Check out buildlog.net for lots of DIY builds. I purchased a cheap chinese laser after using a substantially more expensive one at work and wanting to be able to engrave things without feeling guilty if i then sold them. Its not great but with the improvements i'm making its good enough for what i need for the time being.
We converted a large manual mill to CNC about 2 years ago, use Mach3 as a controller and i toyed with the idea of somehow rigging up a laser tube like you mention. I quickly gave up on that idea, the laser tubes themselves are of a substantial size and i don't think its feasible to mount one on a z axis. This means the conventional, mirror solution is needed, with the necessary beam alignment moving from the spindle to the laser wouldn't be a quick swap. Added the fact that the chinese lasers don't cost much more than a 40w laser tube for me is a no brainer.
				Actually, I think aside from the fumes, and fire hazard, the biggest risk is to your eyes.
Agree with Dave about combining milling with laser, there's probably some good reasons why they aren't available.
That said, I'd totally want to try to make either one or both if I had the time.
I forget where, but I've seen builds using dvd-r and inkjet printer parts. Most likely an easier way to do it but it's not 3d, not sure about effectiveness either.
				Quote from: wgc on July 22, 2014, 01:52:25 AM
Those are less dangerous, but also much lower power.  Many of the DIY designs I've seen are based on that.
wll i have to build it and see what happens, maybe i can make both, if i have the lucky to get thos tiny IC again, to make the drivers, co2 will be later, i got some laser over there to try the hardware and then the big laser(the most dangerus part), but i think its gonna b fun and amazin if it work, but i have never used a laser engraver only some 12 axis cnc centers, engraver are new world to me so... i have to learn so much
				I've never seen a 12 axis engraver in action, but the 7 axis was AWESOME.  You can do so much with those.
We have a four axis at work for prototyping.  It's very cool.  The only downside is how long it takes if you do a detailed finish.  Some jobs get roughed out in 30 minutes or so but the detail work takes another 12 hours.
				Quote from: pickdropper on July 22, 2014, 12:04:15 PM
that a long time to wait, but i think 4 axis its out of my wish for now, maybe i can use it later, the problem its only have 3 drivers for my stepper, and i cant get any DRV8825 chip to make more, i need to trace those IC
