Projects => General Questions => Topic started by: blearyeyes on July 24, 2014, 04:30:34 AM
Title: Simple LED question....
Post by: blearyeyes on July 24, 2014, 04:30:34 AM
When you are making a PCB, is the Anode usually the square pad or the round one? I would think the Anode is square as it is + ....right?
Title: Re: Simple LED question....
Post by: RobA on July 24, 2014, 04:56:09 AM
The convention doesn't seem to be very conventional :D. I've seen all sorts of things done for LED's and pads. For diodes in general, the square pad usually goes with the cathode, but LED markings seem to usually go against that trend and the square pad goes with the anode and the long leg (it's also denoted as pin 1 in lots of parts libraries). But, I've seen it done the other way too. I mainly depend on the silk screen indicators and if I'm still confused I follow the traces.
Post by: blearyeyes on July 24, 2014, 05:23:04 AM
Thanks, I just wired leds backwards because the anode which is positive and has the long lead would tend to go into the square pad as Electros do but I guess I better be more careful and like you said look at the schemo...PITA IMHO..
