Projects => Tech Help - Projects Page => Topic started by: mjcyates on July 29, 2014, 01:39:17 PM
Title: Mudbunny (P19) help needed
Post by: mjcyates on July 29, 2014, 01:39:17 PM
Hey guys I am building a P19 using a Mudbunny 2010 board and Juan's Muff spreadsheet. I have it built but it does not seem to be functioning properly. When I have the volume and sustain dimed it is barely above unity and sounds like a low gain overdrive. I played through a Skreddy P19 yesterday at a local store to see what it should sound like and my build is miles apart. Any ideas on what the issue could be? Thanks in advance.
Title: Re: Mudbunny (P19) help needed
Post by: selfdestroyer on July 29, 2014, 05:12:53 PM
Did you use the BC550C trasistors? If so, did you make sure they are all flipped since they are 180 from 2N5088 on the mudbunny? Just a thought.
Post by: mjcyates on July 29, 2014, 05:22:57 PM
I would say that is the problem. I did use BC550 transistors but I did not flip them as I didn't realize they had a different pin out. I will swap them out tonight. Thanks for your response.
Post by: mjcyates on July 30, 2014, 12:48:01 AM
Amazing how much better things work when you follow directions. Flipped the transistors and it works like a charm. Thanks again for the help.
Post by: selfdestroyer on July 30, 2014, 08:16:23 AM
Quote from: mjcyates on July 30, 2014, 12:48:01 AM
Glad it worked for you. I only know the solution because I have done the same a few times. That's how we learn.
