Projects => General Questions => Topic started by: mattpoole on April 27, 2011, 02:04:04 AM
Title: fatpants c1 question
Post by: mattpoole on April 27, 2011, 02:04:04 AM
will this cap be ok for a fatpants? (i was worried about it's tolerance being a high %)
- Manufacturer: Panasonic
- Part Number: ECK-ATS221MB
- Capacitor Type: Ceramic Disc, Y5P Dielectric
- Capacitor Value: 220pF
- Capacitor Voltage Rating: 250VAC Y1 / 440VAC X1
- Capacitor Tolerance: +/-20%
- Operating Temperature: -25C to 125C
- Lead Spacing: 0.295" (7.0mm)
- Diameter: 0.276" (7.00mm) Max
i have the board populated minus c1, i some how missed that when sourcing parts.
thanks,
matt
Title: Re: fatpants c1 question
Post by: madbean on April 27, 2011, 02:10:19 AM
Matt, that should be fine. 7mm is a little wide (I think the spacing is 5mm on the PCB) but you will only need to bend the leads inward slightly.
Post by: mattpoole on April 27, 2011, 03:35:59 AM
thanks, that´s a relief i ordered a 20 pack on ebay.
Post by: bigmufffuzzwizz on April 28, 2011, 01:21:53 AM
Quote from: mattpoole on April 27, 2011, 03:35:59 AM
EHX is notorious for using ceramic disc caps as their capacitors in big muffs.  :)
