Projects => Build Reports => Topic started by: PhiloB on August 19, 2014, 01:57:58 PM
Title: Tourbillon Phaser
Post by: PhiloB on August 19, 2014, 01:57:58 PM
Got this PCB from aballen as a PIF.  Thanks bud!  It is subtle but sounds great!!  Shout out to Mike Flanagan for the clear orange led.  I tried out a red diffused but the clear orange did sound better so I went with it.  As you can see, I consider this a Madbean build seeing as so many others contributed:) This is a great community.
The most interesting feature of this phaser is the shape pot. It is really cool - it allows you to select the 'vowel' of the phase.
I've included an audio sample but it really is just me playing through the pedal rather than a proper demo of what the pedal can do.  The rhythm guitar has the most pronounced effect of the 2 guitars.  The melodic guitar has a really slow phase with shallow depth.  I probably went too subtle.  The other effects heard are from Garageband (Delay/Reverb).  It is best heard in headphones due to the stereo delay;)
[soundcloud]http://soundcloud.com/resuggan/tourbillon-phaser-1[/soundcloud]
http://soundcloud.com/resuggan/tourbillon-phaser-1 (http://soundcloud.com/resuggan/tourbillon-phaser-1)
Title: Re: Tourbillon Phaser
Post by: jimilee on August 19, 2014, 02:01:42 PM
Man, that's truly awesome, I'm gonna build mine next along with the doppelganger and the 30 some odd other boards I have, ooh and the sparklehorn I just got, I may need some help....
Post by: flanagan0718 on August 19, 2014, 02:17:36 PM
Glad I could help out. This thing sounds great!! I'll have to move it up in my list. Maybe a 2 in 1 with a verb or delay would be cool.
Post by: culturejam on August 19, 2014, 03:12:07 PM
Nice work, and sounds very nice!
Post by: PhiloB on August 19, 2014, 03:54:23 PM
Can't believe I left this out:
If you're going to build this one, don't be a bonehead like me.  It clearly states on Rej's site that there are some resistor changes that need to happen from the BOM to bring the pedal to unity volume wise.
I read this and THEN proceeded to populate the board according to BOM.  At which point I was confused as to why there was a volume drop.  Pretty embarrassing.
While trying to remove the wrong resistors I lifted a pad but managed to work around it.  I learned that desoldering braid works better than a solder pump at times:)
Post by: Cloverleaf on August 19, 2014, 04:45:08 PM
Wow, sounds absolutely fantastic... think this'll be the next phaser I'll be building! :)
Post by: bcalla on August 19, 2014, 05:51:07 PM
Great build & demo.  I love the sound, I don't know why I haven't built mine yet.  Just bumped up the priority.
Post by: pickdropper on August 19, 2014, 06:12:48 PM
Very nice build and the demo sounds great.  I may have to get around to building this one.
Post by: GrindCustoms on August 19, 2014, 07:15:48 PM
Wow, you really nailed, sounds great, clean guts and nice enclosure. :)
Post by: PhiloB on August 19, 2014, 07:22:56 PM
Thanks guys.  You have a great PCB here Rej.
Post by: PhiloB on August 20, 2014, 01:10:13 AM
I've been thinking, it might be cool to put this effect in a wah shell and wire the shape to the wah pot.  Nice, slow sweeps might be cool:)
Post by: jimilee on August 20, 2014, 01:38:33 AM
Quote from: PhiloB on August 20, 2014, 01:10:13 AM
Sounds like you need to build another!
Post by: juansolo on August 20, 2014, 07:50:53 AM
They're a bit of a fiddly build, but a cracking phaser. Some really nice sounds in there.
Post by: wgc on August 20, 2014, 12:29:26 PM
Looks and sounds great!
I much prefer wick. Bummer about the pad.
Next time, reflow the joint from underneath and use needle nose or tweezers  from above to pull out that lead only.  Don't pull too hard, make sure the joint is fluid first.
Repeat for the other lead.  Don't worry about wrecking a $.03 resistor, save the $10 pcb..!  You can even clip the part out first and then remove the leads.
Then when the part is out, wick the holes.
It's a little awkward at first, but much easier in the end.  Also make sure your iron isn't too hot, pads will lift a lot quicker that way no matter what you do.
Post by: PhiloB on August 20, 2014, 05:36:40 PM
Part of the issue is my iron.  I got it from Home Depot.  It is an 18watt iron that is "equivalent to a 40W iron".  Not sure what that means but I do know that it gets a little too hot.  I am careful and haven't had but a couple issues, both related to desoldering and lifted pads.
Need to resist buying new parts for pedals and save my pennies for a decent adjustable one.
Post by: aballen on August 29, 2014, 09:08:52 PM
Really nice playing man, I have to get some clear orange leds for mine.
Post by: jimilee on August 30, 2014, 01:31:04 AM
Quote from: aballen on August 29, 2014, 09:08:52 PM
It's a clear orange led?
Post by: PhiloB on August 30, 2014, 02:58:29 AM
I ended up using a clear orange 3mm. And I placed the LDRs pretty close to the LED
