Projects => General Questions => Topic started by: Stig on September 16, 2014, 07:26:32 PM
Title: Moodring regulator
Post by: Stig on September 16, 2014, 07:26:32 PM
Hi all.
I am about to make a Tayda order for the Moodring parts + some bibs and bobs.
The problem is they don' t have the LM78L05. Or that is they do, it´s just an smd ic. Guess that wont work.
Are there any other that will get the train in the station... As you say   ;)
Any help appreciated.
EDIT:
There are this little bugga:
http://www.taydaelectronics.com/l78l05acz-l78l05-78l05-5-volts-100ma-voltage-regulator-ic.html
This is the same as in the tenebrion. Is this it?
Title: Re: Moodring regulator
Post by: Shrtyska9 on September 16, 2014, 07:46:41 PM
As far as I can tell that's the regulator you are looking for.
Richard
Post by: m-Kresol on September 16, 2014, 07:51:26 PM
I would say the same. There are different packages out there. you need the 3pin version (TO-92), so this seems to be the right one.
Post by: Stig on September 16, 2014, 07:57:45 PM
That was fast. This must be it then.
Thanks for your fast replies and help.
