Projects => Tech Help - Projects Page => Topic started by: tenwatt on May 06, 2011, 12:51:36 PM
Title: Road Rage (Stand Alone)
Post by: tenwatt on May 06, 2011, 12:51:36 PM
So I want to build a Road Rage in an enclosure.  I just want 9V in and 18V out.  I have two questions.  Does this mean I don't need a regulator at all?  Is there a certain jack/cable that I need to use on the 18V side that will attach to the pedal?
Title: Re: Road Rage (Stand Alone)
Post by: cjkbug on May 06, 2011, 01:12:52 PM
you do not need a regulator for 18v oeration. and you can use any 2 contact jack you like. but the standard power jack will correspond with most available power cables. you could also use 1/8 phono jacks like the old dod pedals. IIRC the furman powered pedalboard cables use those.
